Results 1 to 5 of 5
Thread: Vacuum pump wiring.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Vacuum pump wiring.
    Am I only supposed to have two wires going to the vacuum pump? I have power going to the pump but can't get it to cut on. I have a different pump that won't cut on when plugged in.
    Quadratechtown, PA
    5, 7, 4x4
    The round plug should have voltage on car start up and other times, too, but will turn off if the vacuum demand of the HVAC system is met by the engine vacuum. It is a part time vacuum at best if it even works. The pumps can die and then they don't cut at all. Check the resistance of the vacuum motor to see if it is burned up vs. stuck and not moving. Both do not allow the motor to cut on.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Yep two wires, brown and a green one. Brown grounds at that main bolt at the base of fuse box, green is that small square plug by paint code.
    Chances are, the bearing is seized due to 100% duty cycle... this is not how it is designed. It runs always due to major system leaks.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    That's what I figured happened. I bought a used one on eBay that is probably bunk as well.
    Hamburg, NY USA
    e23, e32, e34, e39
    There's supposed to be a Ford truck that uses the same pump, I'll have to see if I can find the post.
    http://bimmerboard.com/forums/posts/1085678
  1. Replies: 4
    Last Post: 11-09-2005, 12:52 AM
  2. Snap On MityVac Brake Bleeder/Vacuum Pump Kit
    By kendogg in forum BMW Parts For Sale
    Last Post: 08-03-2005, 10:27 AM
  3. Fuel pump wiring
    By ttw18 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-06-2005, 02:03 AM
  4. Fuel pump wired directly to the battery?
    By rollinwardle in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-23-2005, 11:10 AM
  5. 1985 Bmw 735i A/C Vacuum Pump Wires missing
    By Jokester_9900 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-26-2002, 05:28 PM
