Results 1 to 22 of 22
Thread: How bad are these eBay caps and rotors?
    Mar 2012
    Auckland, New Zealand
    1991 BMW 850i
    So I need to replace my caps and rotors and the stealer here in NZ wants neatly US$350 for each side. I can, and will, purchase for a lot less online but I wondered if anyone had tried these cheapie (less than a tenth of the price!!) eBay ones? https://www.ebay.com/itm/332146043831
    They're not exactly complicated. Is it possible an Asian manufacturer has ripped them off and done a good job or am I wasting my time?
    La Costa, California
    1994 850CSi #125
    I have used those from eBay without issue. As you said, they're not exactly complicated so it's worth a try to save so much cash.
    Taylor in Carlsbad
    P=(p x v3 x Cd x A)/2
    Oct 2003
    Seattle
    99 M3
    I see a Bremi variant for $75, also on eBay
    Jul 2016
    Chicago, Illinois
    are slow
    I'd take the risk.
    $55 vs $180+ and shipping
    Sunny Cali,
    6.5 second 69 Camaro
    Arizona Autohaus, I got Bosch same parts for $175.00 Both sides.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by jeffbebe View Post
    Do not buy, those are known to bind with each other!
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by dragon850 View Post
    Hammer it off?
    Mar 2012
    1991 BMW 850i
    Quote Originally Posted by 8eights View Post
    Just looked. Even cheaper for Bremi but $100 to ship!! Crazy.
    Causing damage to the engine or just a PITA?
    Quote Originally Posted by taylorpatterson View Post
    Thinking of doing so. Even independent parts stores want NZ$350 for just one cap here!!
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    No engine damage just a no start situation, look for bremi on ebay with cheaper shipping.
    Sent from my SM-G925T using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    One of my wrenching buddies bought some from/made in China, maybe he was unlucky, but even the bolts in the distributors did not fit exactly into the thread holes, 1 rotor cracked while installing it.
    I would buy Bremi or Bosch.
    FCPEURO ships cheap to Asia/Oceania and they have Bremi on sale https://www.fcpeuro.com/BMW-parts/85...90&m=20&page=1
    Bremi distributor $39.69, Bremi rotor $ 21.99
    Mar 2012
    1991 BMW 850i
    Shogun is right. Unfortunately, I didn't read his post until after I'd bought and paid for the cheapies. One rotor snapped on install and the distributors had a slight curve that meant they wouldn't sit flush to the engine. Fortunately, the vendor immediately offered a full refund and Shogun supplied a pair of brand new and very reasonably priced Bremi caps and rotors which arrived in New Zealand from Japan in 2 days! Now that's service. Oh, and the car works runs beautifully once more.
    UK
    e34 540 e30 335
    Quote Originally Posted by shogun View Post
    Similar thing happenned to me.
    E30 1992 335 Cabriolet - Transplant nearly finished
    E31 1992 850ci - Hartge H8 6.0 conversion
    E34 1995 540A - Stock, low mileage, hi spec and soon to FI'd
    E36 1994 M3 - GM LS3 Transplant
    E38 2001 735 - Daily driver
    E46 2002 330 Cab - Stock
    M62B46 with TTV flywheel, dual plate clutch and 6 speed box sitting in a corner waiting for me to decide where to put it.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Guys, do not buy Chinese caps and rotors, they do not align well and rotor rubs on the cap or worse.
    I have helped several E31 owners troubleshoot the car where they have gone though virtually everything in the car to find out why it's not starting and then find that caps and rotors are defective!
    Sunny Cali,
    No way, Cost me $15.00 for shipping including belts tentioners and plugs.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    He is in New Zealand.
    Sunny Cali,
    oopz, Thanks!
    Mar 2012
    1991 BMW 850i
    Does anyone have any experience of Facet aftermarket parts? After a crankshaft sensor and the RRP in New Zealand is $350!! Around $100 on ECS but they want $75 shipping! An eBay seller I have used before for OE parts only has a Facet sensor listed. This seller has been great before but the price (about a third of the ECS cost inc shipping) seems low, so I'm concerned about the quality and obviously, this thread shows, that cutting corners doesn't usually pan out well.
    Sep 2017
    Ontario
    1991 BMW 850I E31
    I purchased 2 of the Airtex/Wells crank sensors which i believe are Facet so far they seem to be working. The only issue I had with them was the orientation of the plugs and the bolt holes they do not have the same angle as the OEM ones and it forces you to bend the wires quite a bit as to not hit the belts or other parts.
    Jan 2005
    Japan
    Autohausaz has the Facet now on sale for $35.19. http://www.autohausaz.com/pn/12141720307 $35.19 SALE$37.44 List: $94.58
    No personal experience so far on my side with them, maybe o.k.
    Important for you in NZ: they offer now Discounted International Shipping 55% discount off UPS published rates on international shipping.
    and: All parts are covered by a 24-month warranty (24,000 miles) , unless otherwise specified. So you might give it a try.
    and here we go, personal experience is o.k. https://www.bimmerforums.com/forum/s...S-12141720307)
    comment by another member in the E34 forum:
    Sudden death like that is very often the crank pos. sensor. The bitch is they are frequently intermittent( & temp sensitive) and of course won't break up when you want them to. Your description of the "rev limiter" feeling sure sounds like it lost spark momentarily. You wouldn't think a fueling issue would feel that way. Me, I'd test fuel pressure to be sure and if the pump is healthy throw a crank sensor on it. Wouldn't waste $$ on a spare, they (good ones) last a very long time. I have had 50/50 success giving dead ones a smack that wakes them up at least long enough to get home. Not sure about access for said smacking with the V-8.
    by ross1
    Mar 2012
    1991 BMW 850i
    Thanks Erich. I purchased the Facet ones and will install next weekend. Bit worried by the cable length though. Looks fine for the top sensor but the cable looks a bit short to reach the lower one by the PS pump. Hopefully just an optical illusion but any insight would be helpful.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    I installed Facet crank position sensors in my car. They fit and work perfectly.
    Orlando, FL USA
    Quote Originally Posted by BMSman View Post
    Yup, same here. Replaced both of them with the ones from Autohausaz about 8 years ago and still going strong. Well, I've only driven about 6 thousand miles total in the past 8 years....hehehe.
  1. How Bad Are These Guides?
    By Nunthewiser in forum 1988 - 1996 (E34)
    Last Post: 11-27-2016, 02:09 PM
  2. Replies: 1
    Last Post: 03-24-2013, 07:53 PM
  3. How bad are these photos?
    By Bear Grylls in forum Photography & Multi Media
    Last Post: 12-26-2010, 03:11 AM
  4. how bad are these spark plugs? see picture
    By Plagueoc in forum 1992 - 1999 M3 (E36)
    Last Post: 05-16-2008, 04:27 PM
  5. how bad are inpro and other non-zkw ellipsoids??
    By Dark Vadors in forum BMW Rides & Events
    Last Post: 12-14-2003, 06:44 AM
