Page 1 of 4 1234 LastLast
Results 1 to 25 of 89
Thread: New member, first e36
    May 2017
    Owings, Md
    1998 328i
    So I bought a 96' 328i with 69k miles (according to the dash and records but I'm afraid to learn otherwise) off a used car lot for a cheap but fun commuter. It was recently repainted, a "value" job but it shows pretty well in pictures. I tend to keep vehicles for a long time and my long commute racks up miles quickly but I wanted something I wouldn't mind working on with decent parts availability. The car was on ebay and some of you may have seen it, I purchased it locally from the dealer and the sale was a comedy of errors. The seller put it through state safety inspection and during the process, the hood flew up and smashed the windshield while the inspector was testing it. Fortunately for me, the hood had a couple of scratches in it prior to the incident so now it has a different hood with fresh paint. Then the steering rack was an issue and finally the power steering pump was replaced as well. Right about the time I was convinced I had been scammed out of a deposit, the car was finally ready for pick up and it is now my daily driver.
    I'm working through a short list of bugs and I'm sure there will be more to come but so far I think it will work out.
    May 2017
    Owings, Md
    1998 328i
    This weekend I plan to replace the right trailing arm bushing as well as the oil filter housing gasket. It also needs a new windshield washer motor and coolant level sensor which are in the mail. There is an srs issue to sort out and some noise in the front suspension but in the mean time I am racking up miles on it.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    I would replace both bushings as a pair.
    Also, just figured I'd mention I have the RTAB bushing tool and an SRS scanner I'll rent out. PM me if you're interested.
    May 2017
    Owings, Md
    1998 328i
    Quote Originally Posted by Nanniepoo View Post
    I should have just ordered two but was(still am) in the phase of doing the bare minimum into the thing until I'm more convinced I haven't dragged home a doped horse if that makes any sense.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    I get it, but you should still get an alignment after replacing your RTAB. And if you're getting an alignment, might as well drop the extra ~$20 instead of having to replace it next year and get another alignment. Just my $0.02.
    May 2017
    Owings, Md
    1998 328i
    You're right, doesn't make sense to spend alignment $ twice. I'll shade tree align it for now and find a shop that can do a good job once I finish going through the front end and the driver side trailing arm bushing. The only shops I've ever used are just tire places that claim to do a full four wheel alignment but really just set the toe-in. I ended up redoing the alignment on my trailblazer after the shop claimed there was no way to adjust the camber. I do have a level garage, turntables and a castor/camber gauge.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Mark the RTAB plates, the holes are slotted to allow for toe adjustment. I check the toe with a tape measure and also use a long straightedge on each side to make sure it is evenly distributed on both sides.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Mar 2014
    Sammamish, WA
    1998 M3/4/5
    Car looks nice! I dig how clean/stock it looks. Classic. Enjoy!
    1998 Titanium/Dove M3/4/5
    2020 Toyota 4Runner
    May 2017
    Owings, Md
    1998 328i
    Thanks for the tips, I wouldn't have bought this thing if not for the wealth of knowledge shared on forums like this.
    Jun 2016
    California
    E36 325is
    Quote Originally Posted by gdavid View Post
    The local good year tire quoted me $180 for a three year unlimited alignment plan after I told him I would need at least two more possibly three more alignments.
    Trumbull CT
    1998 M3 Vert, 1992 318i
    Quote Originally Posted by FiberFast View Post
    Firestone has a $200 lifetime option as well
    Caprica Junkie
    May 2017
    Owings, Md
    1998 328i
    Got the RTAB changed along with my coolant level sensor and winshield washer pump. I marked the cassette position but it was almost like the alignment had been set with the broken bushing, it wasn't torn but the rubber was intact and separated from the metal allowing the front of the trailing arm to rotate inboard as the wheel pushed the car ahead. Anyway I ended up toed out at the marked position and pulled the rear to the right such that it crabbed down the road with the steering wheel cocked to compensate. After matching the toe to the left side relative to the front wheels it feels great. I have some general groaning from the front as I come to a complete stop and as I take off again, subtle but my next task after the oil housing gasket.
    Apr 2015
    USA
    1998 BMW 328is
    Nice car. Welcome aboard.
    McKean township Pennsylva
    1999 M3 , 1999 328is
    Looks like fun! The engine in the 328 is an absolute gem, it makes some of the best sounds I have heard come from an engine on down shifts.
    Welcome to the e36 world.
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
    May 2017
    Owings, Md
    1998 328i
    So a few more days with the car and I'm continuing to learn more. One major realization was what the ASC light is for, pretty boneheaded of me but I wasn't familiar with the symbol and though it had something to do with the check control. It is coming on after the car has been running a while so it seems like a bad electrical connection somewhere. I have seen the DIY fix for the brake pedal travel sensor and will dig into that if it isn't just a bad connection elsewhere. I'm beginning to suspect my head gasket is leaking, I haven't seen any white smoke or milky oil but I do seem to be loosing a bit of coolant and don't see any external leaks. It could just be working some air out of the system (I changed the coolant level sensor, it was bad) but I don't want to live in denial. The engine temps have been rock steady. There is a lot of carbon buildup inside of the valve cover and my skepticism about the car's mileage or at least this engine's mileage is growing. I'm not intimidated by a head gasket job but I am nervous about what else I may find as I tear into it and how long it will take. If the coolant use remains pretty steady, I may pick up a spare engine that I can take my time going through and switch it out over a weekend. I kept my old commuter in anticipation of the 21 year old e36 requiring some down time but I have grown to hate driving the old (actually newer) car so much I want to keep it to an absolute minimum.
    I have some rust hiding under the rocker panel covers, on the driver side, it is rusted through just forward of the wheel where it as creased up by something and there is some rust peaking out above the cover on the passenger side. I don't think I want to mess around with patches, a complete replacement on both sides may be less work in the end, I've replaced rockers, front & rear clips before and think I will bite the bullet and be done with it. I still haven't inspected my front suspension, it is noisy when it is hot out or after a long drive in the afternoon. I think it could be anything from sway bar hardware, strut mounts, control arm bushings, subframe bushings or all of the above.
    Yeah, so like I said, I expected a couple of bugs to pop up.
    Jun 2016
    California
    E36 325is
    You sound like every other e36 owner I have ever heard. My solution was to find a low mile engine and swap it, now I have my old m50 sitting and waiting for an overhaul. I recommend this route as it's easier to do things right when you are not in a rush to get the car back together, and with m52's to be had for $200-$500 there is no reason for an engine bay nightmare.
    May 2017
    Owings, Md
    1998 328i
    Yes, this makes alot of sense. I am shopping now.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Just a heads up as you may not be familiar. It is usually not just a head gasket, cracked heads are typical, inspect very carefully around the exhaust valve seats to the cooling ports. You could do a leakdown test or a hydrocarbon test on the coolant to help figure it out rather than making assumptions. When buying these cars stay far away from anything that mentions recent work on the cooling system in any way. Usually trying to solve an overheating problem due to a cracked head.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Congrats on the new ride! I'm attaching a link to our site's DIY tech articles on the E36 platform - I think you'll find it helpful when doing any maintenance or repairs. Please let us know if you have any questions!
    BMW 3-Series E36 (1992-1999) Technical Articles
    888.280.7799 | 6am - 5pm PST
    May 2017
    Owings, Md
    1998 328i
    I changed the filter housing gasket today and it probably was fine. The vanos line is leaking and I wish I had ordered one but it is on the way now. On a positive note, it was tough to get the oil filter cap off and would have been much tougher with the housing in place. The filter itself looked terrible, it was dirty as hell and trying to collapse, don't know the last time it was changed. The oil itself wasn't bad, no coolant and I am less convinced that the head gasket is bad. My coolant level has been stable for 300 miles. On an odd note, I don't have an idler pulley or bracket for it. I have the stock mechanical tensioner (no hydraulic upgrade) but someone decided to leave the idler off at some point. The pulley itself is readily available but if anyone has a spare bracket for it, I would love to buy it. I am still planning to buy a spare engine but this m52 may last for a while. I really want to swap it out and be able to go through it without a rush. Again, I really appreciate the advice thus far.
    Dec 2014
    Stuttgart, Germany
    One Too Many
    make sure the oil filter housing gasket does not leak, I had quite a hassle with mine earlier this year, finally what solved it is putting a thin bed of red rtv around the edges, perfect, been doing fine since, also the oil filter cap oring, somethimes is not oval as it should be and instead square and thus results in leakage, as it happened to me.
    But yea, address it all, see where it goes, these are nice motors and do last a long time if taken care of well.
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Quote Originally Posted by MisterM52 View Post
    The post right before yours says he just changed the OFH gasket.
    Cap o-ring should be changed with every filter change and should really never be a problem.
    May 2017
    Owings, Md
    1998 328i
    It would be really disappointing if the OFH gasket leaks after replacing it because it probably wasn't leaking to begin with. After getting it pulled off, I believe it was all coming from the vanos line (I think BMW calls the hose a "pipe" for some goofy reason) which is unfortunate because I didn't have a replacement on hand.
    Is the idler pulley (not the tensioner pulley) secured with the upper bolt of the alternator? I don't recall any extra length to do so, but I'm not too sure of my memory and it may have the wrong bolt in it. Mine idler is missing and I can't tell from pictures if I am missing a bracket or not. I know that idler does come with a bit of a casting connected to it but can't tell from pictures if that is what attaches to the oil filter housing or if there is something else I am missing. Mine has the mechanical, spring loaded tensioner (not the hydraulic one line for the A/C belt) which I do believe makes a difference.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Looking tidy.
    IG:
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Some M52s have an idler, some do not. Mine doesn't which was quite a surprise coming from an M50
  1. New member, first pics! (e36 content)
    By klodkrawler05 in forum BMW Rides & Events
    Last Post: 10-25-2011, 01:31 PM
  2. New Member + his E36 Sedan and Street Bike
    By Eur0Tun3r in forum 1991 - 1999 (E36)
    Last Post: 02-12-2005, 09:39 AM
  3. New Member.. First BMW
    By meinkaru in forum 1988 - 1996 (E34)
    Last Post: 01-05-2005, 01:55 PM
  4. New member! First post!
    By kgwld1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-14-2004, 01:45 PM
