Results 1 to 24 of 24
Thread: so just how important is a handbrake?
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    i've built my car for the street and grip more so than drift. but i feel like i'm an alignment and some practice away from it being a decently capable drift hog.
    Thad (tptrsn) raves about how much fun he has compared to other disciplines of motorsport and he's got me wondering if i'm missing out. MDU and Drift Indy are pretty active in my area (greater Indy metro). i feel like it wouldn't be too hard to get out to some practice events and tear some isht up.
    but here's the thing.
    my car is wildly allergic to weight.
    i have spent a decent amount of money and time removing weight from my car. i'm extremely hesitant to go shoving 10, 20, or more lbs back in so i can pull a handbrake like K. Bluss or J. Deane. i'm not likely to become a die-hard drifter. and i'm not prepared to make my car totally un-street-able. my parking brake works fine. it was refreshed ~10,000 miles ago and it's depressingly flat in this part of the country. so my parking brake is hardly worn. i've seen the extensions and even dudes out there yanking TF out of the stock parking brake. my worry there is the likelihood that it'd stay engaged...like it's supposed to. lol. i'm sure you clever devils have worked a way around that. but i'll be damned if i know what/how you do.
    so enlighten me, if you please. do i need a hand brake? or will my LS and aggressive clutch be sufficient to drift?
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    Having a working handbrake makes a huge difference if you want to be cool. 10lbs would be one heavy brake, the only real weight it would add would be the handle, there's nothing really significant to the bracket, and a cylinder is a cylinder. The weight is being added in the middle of the car, so it's not going to affect anything (in my mind anyways) but, lots of guys work with a factory cable setup and have no issues. I just got tired of having to mess with tightening the cable
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    For starting out I would say you don't NEED a handbrake. It is a tool and a very useful one at that. Is it a necessity? Not really unless your doing some more advanced drifting. Most likely for a while you will be doing solo runs and you probably won't be entering in slow corners fast anyway.
    That being said having one that works well is very nice to have the option of using it if needed. I have a full dual caliper setup on my car and I mostly only use it when following in tandem. I usually use Angle to scrub speed in lead position. Its a preference thing.
    fairfax,va, usa
    2 E30s and a maxima
    Is it necessary? No. Is it useful? Yes. There are some tracks that I simply can't complete without a handbrake. But if you don't tandem and your average track is just a parking lot, you'll hardly ever touch it.
    With that said, if your car reacts to 10lbs, you did something wrong to setup your car. Regardless, your stock hand brake can be modified easily. Press the button in, drill a hole through the handle and the button, and put a pin in there whenever you want it to not "stick". Then slide an extension over top of it or something to get extra leverage. Pull it off when you're ready to go home. Tada!
    Although factory hand brakes on our cars suck. I recommend full dual calipers that don't sacrifice the factory hand brake. The weight is at the wheel so unsprung weight HELLO! There's lots of options. But the short answer is, do it if you want to be good at drifting. Not just alright.
    Apr 2009
    Greenwood, IN
    2001 BMW 330i
    Do not worry about a handbrake. You are also incorrect about not becoming infatuated with drifting. You will be hooked and it will ruin you. <3
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    Quote Originally Posted by Mikestokman View Post
    I can definitely see how you could add 10-20 pounds when going with a dual caliper setup.
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    My proposed weight penalty is for a complete standalone handbrake. So handle, bracket, cylinder, lines, and calipers.
    I'd also end up replacing my stock calipers with wilwoods to help offset the unsprung weight. Hoping two wilwoods weigh about the same as one stock iron boy.
    I'm more interested in having fun and increasing my level of car control than being competitive.
    i may just try to do a 'back to basics' event like it is and go from there.
    thanks for the input!
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    I ran without a handbrake for a couple years, Clutch kicking my way around the courses.
    After getting good enough to see the benefit and adding the asd inline set up, My speed drastically increased, my car position relative to the corner is better, and those "oh shit" moments are easily controlled.
    if weight is all your worried about, add it. You have a lot more grunt than the stock M50 guys with one. Start eating healthier to make up for it at least. lol
    As soon as you start drifting, you'll be hooked, and wonder why you didn't add one in the first place.
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by blake261 View Post
    i need to start eating better anyway. Lol. I don't have the metabolism of you young guys anymore.
    but if fun can be had just clutch kicking the hell out of it, I'll try that. I'm told it's better to learn drifting progressively and I already have a car much more capable than I am.
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    a good handbrake really helps with tandem. I have an inline hydro in my car and use it all the time now. A lot of it is driving style as well, Jeepster rarely touches his.
    Also, I barely used mine last year either, you'll have plenty of fun clutch kicking
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by Novablue454 View Post
    Awesome.
    also, I can't tandem as I don't have a proper cage. Just a bolted in half-cage. Although I'm considering welding it in.
    Jun 2012
    Socal 818
    Slow e36
    stock ebrake is more then enough to have fun as long as it functions well
    fairfax,va, usa
    2 E30s and a maxima
    Back in my day, we didn't have hand brakes. We used the foot pedal parking brake. And we liked it that way.
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by protomor View Post
    I've been in a mid 90s grand am (Pontiac, not GA cup car) going 60 sideways with the foot parking brake deployed.
    i can't imagine drifting being more exciting than that.
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    Put in an dual caliper setup and swap to an aluminum block ls and you'll loose more weight then you'd gain by installing the brake #science
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Already have an aluminum LS.
    #gotchabitch
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    Goddamn brain thinking lm4 was iron block like the lm7
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Happens to the best of us.
    flattered you remembered I'm running an LM4 tho.
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    What do you guys think about this?
    http://nerptech.bigcartel.com/product/e-brake-extension
    im ok with $50 and it can come out if I don't love it.
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by doktor b View Post
    I basically made my own version of that with $10 and a trip to home depot. It works well too.
    But nah I don't think you need it to have fun. You will probably get addicted and want it to have more fun though.
    instagram @andyitslit
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I say the most important thing is to get out to an event. Bonus points if you actually pin your e-brake release button in first. You're going to have a blast no matter what.
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    As for the button, uncrew it, take out the spring, push in and it stays in, pull button out for when you need to park and it will lock.
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    Definitely make it so you can pin the button down. I drove a friends 240 where it wasn't pinned and having the brake stick is sketchy
    Jan 2014
    San Antonio
    98 328is
    get out to an event and see if you need it. i have yet to use the ebrake at any of the local events. however, im just basically a stock 328is running on a drift track thats normally a pit area for the local drag strip. 60mph entries on a wide sweeper dont really need an ebrake.
  1. So just how fast is an E46 M3?
    By Metal Made Fox in forum 2001 - 2006 M3 (E46)
    Last Post: 01-08-2020, 04:36 PM
  2. so just how rare is one of these?
    By Da Inunnet in forum BMW Rides & Events
    Last Post: 06-22-2009, 03:01 PM
  3. So, just how fun is an E39 to drive anyway?
    By gwb72tii in forum 1996 - 2003 (E39)
    Last Post: 04-12-2007, 06:39 PM
