Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 101 to 125 of 251
Thread: Budget 4.4+ jaguar supercharger build
  1. #101
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Agree. Makes some calls at the various suppliers and see what is available. It can't be a unicorn configuration. I bet Deves is priced higher, but see what's out there with some calls.
  2. #102
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Yeah, but you didn't say which ones. Some of us are too dense for you to be inscrutable with! [namely this guy ]
  3. #103
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    I can't find a cadillac ring set at summit measuring 93 x 1.5 x 1.5 x 2.0, The groove height measures exactly the same as my 4.4 pistons, are you sure these aren't some kind of specialty bmw pistons?
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  4. #104
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by 1999 540i m View Post
    call the guys who built your 4.5
  5. #105
    Nov 2011
    Greedland
    Quote Originally Posted by XAlt View Post
    I don't know for sure who built it
  6. #106
    Nov 2011
    Greedland
    Anyone have thoughts on this gouge? my fingernail slides past it vertically, but horizontally I can feel it
  7. #107
    DeWitt, Michigan
    Sometimes pictures can be a bit misleading, but that looks a little ugly to me. Is it some crazy macro shot that over exaggerates the size of the gouge by a lot?
  8. #108
    Nov 2011
    Greedland
    Quote Originally Posted by tptrsn View Post
    The first one is super zoomed in, the second shows lots of shadow, and is zoomed in a little.
  9. #109
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    I'm not sure if I missed it, but what is the advantage of using any pistons that aren't either stock or made for the m62?
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
  10. #110
    Nov 2011
    Greedland
    A couple more pics from further away, There is very little depth to the gouge, It looks to me like a slight compression loss and some oil use, do you think the ring could get stuck or worse?
    Rewired one side of the engine, the bundle at the top of the valve cover will run down the middle of the engine,
    Quote Originally Posted by ColtonBH View Post
    None so far, but properly built it would be a 4.5L, this one is not properly built
  11. #111
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Well there's a potential parts / options vs availability / budget payoff if by crazy chance some GM piston fit... But still theoretical to proving it works well.
    BTW just searchin the web pistons for the northstar w coated skirts just like that come up but it's clear the coating is some light duty spray on deal. But the pix look just like what you got so... Would explain a lot...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  12. #112
    DeWitt, Michigan
    As far as the gouge, I say that is the least of the problems, so assuming proper rings can be obtained, RUN IT!!
    Regarding the piston skirt coating, I'm a bit concerned with that too along with GearGrinder it seems, but seriously, if you can find some proper rings, you are too close to not just assemble this sucker and run it.
    I can't tell you (and don't want to think about) how many times I've thought I had an engine assembled just perfectly, and had to yank it back out and tear it back down for various reasons after only a small amount of running. It happens.
    What I've learned from that is that in situations like this you just need to do the "definitely necessary" things and just run the bastard. For me a good set of rings seems necessary, but opinions may vary on that.
  13. #113
    Mar 2012
    Lansdale, Pa
    Eww. Looks like that gouge was there after they machined it. It must have been pretty deep prior. How far above the top ring at BDC? Might be OK, but another core is cheaper than a redo.
  14. #114
    Nov 2011
    Greedland
    Good info, thanks, I just bought 2 spare engines, I do plan to swap engines more than once,
    This is a great learning experience thank you everyone for contributing.
    Quote Originally Posted by philly98540 View Post
    It's around 37mm down to the gouge, I have not done the rest of the measurements.
  15. #115
    Nov 2011
    Greedland
    Something made just for me arrived today,
    Bmw m62tu rings in +1.00mm custom made,
    Slow progress waiting on my orders to arrive, Progress should be jamming at full throttle next week
  16. #116
    Mar 2010
    Cool! ...so plentifully available Caddy pistons are now fully on the rebuild menu for M62's? (assuming all goes well...)
    2003 M3CicM6 TiAg
    Former:
  17. #117
    DeWitt, Michigan
  18. #118
    Nov 2011
    Greedland
    No, not caddy pistons, going by ring size these are oversized bmw spec pistons
  19. #119
    Nov 2011
    Greedland
    So what are the specs and the scoop (full story) on those rings?
    I contacted all the possible suppliers, Deves is out of business, hastings said they had it, then I wanted to order, and they didn't have it
    And then Saturday morning the vice president of Grant piston rings emailed me, they were happy to help, I ordered wednesday and received friday, Excellent customer service.
    The specs are, these are standard bmw spec pistons, just 1mm bigger, so I ordered m62tu ringset .040 over
    This looks like a correct build, bmw spec pistons, bmw spec rings, cylinder walls prepped the best I can, the cylinder to piston clearance measures the same as my old 4.4, at .002"
    I invested in proper measuring tools as many people suggested I do,
    The project continues.
  20. #120
    Mar 2010
    Ah ok I was not following then. I thought you were still on the caddy piston theory
    2003 M3CicM6 TiAg
    Former:
  21. #121
    Nov 2011
    Greedland
    I was until I measured the ring groove, only bmw matches
  22. #122
    DeWitt, Michigan
    Cool, thanks for the info!! I can't wait to see how this works out for you! .002" is about half as much as I like to use for cast iron blocks with boost, but I was expecting these Alusil builds to need less p2w clearance when the block is cold.
    I'm still not real clear about these pistons you're using though? I haven't seen BMW pistons for Alusil blocks that have had the dark colored skirt coatings, but I haven't seen that many bimmer pistons, and probably all of them have been from non-TU M62s.
  23. #123
    Nov 2011
    Greedland
    They look almost exactly the same to me, It looks like the dark coating is just wore off on the original 4.4 piston on the left, It is just a "break in" coating from my research
  24. #124
    DeWitt, Michigan
  25. #125
    Nov 2011
    Greedland
    Test fitting some gauges
  1. Interest on a Very Budget Supercharger Build??
    By MisterM52 in forum 1991 - 1999 (E36)
    Last Post: 06-24-2023, 06:03 PM
  2. Supered's Stage 2 RMS Supercharger Build Thread
    By Supered M in forum Forced Induction
    Last Post: 03-26-2013, 09:23 PM
  3. Replies: 2
    Last Post: 10-31-2009, 12:34 AM
  4. Supercharge build! What els do i need?
    By Deca in forum Forced Induction
    Last Post: 02-11-2008, 09:09 AM
  5. Supercharger Build
    By Zombie63B in forum 1975 - 1983 (E21)
    Last Post: 10-17-2007, 07:57 PM
