Does anyone know what the piston numbers mean?
93.00
+1.00
02k29
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
93.00 (standard bore size in mm)
+1.00 (mm over size)
02k29 (29th week of 2002?)
Have you got an inside dial calliper you can use to measure the bore?
Perhaps this is a non starter attempt at a rebuild with a rebore... Which could explain the new looking cross-hatching
Absinthe makes the tart grow fonder
I think the guy must have recently Sea Foamed the engine.
~2001 540i/6speed~
Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
wtf is going on
-$500
-93mm bore and B46 pistons
-presumably needs to be rehoned
You need a dial bore gage and have to check at least six places in each bore- top, mid, and bottom of the stroke parallel to the crank and perpendicular to it.
You need to be sure the bores aren't barreled.
If size is on, and cross hatch looks good, it is good.
Check piston skirts for scuffing and check their sizes as well.
Check ring gap widths and make sure they are clean. (A broken old ring makes a good gap cleaner) New rings should be on the list even if it was a recent rebuild. More than once I've run into compression rings on "rebuilt" engines with stacked gaps. That doesn't work well.
Since it has been rebuilt I'd also verify piston height. It may have been decked and you need the appropriate gasket if so. But I imagine you are already looking at that since you are putting blower on top.
Since I now have a 4.5L same bore size as the 4.6, do I use the 4.6 head gaskets?
Measure first, check your bore properly and then swept volume as you check your deck height.
Only then can you be 100% sure what you've got, and it takes no time to check.
I think there is a way of checking what the block was manufactured as, to give you an idea of the how and where it's been modified, and then you can decide on your next course of action... Whether that be just put it together and hope or take the pistons back out to give the bore a surface treatment, if only to be sure.
I am planning to polish the cylinders with the an-30 and felt pads, reading all the above posted threads has been very informative
I confirmed with the machine shop this engine has never ran after rebuild, there is still green machine goo on the valves.
This is now a 4.5L build
I ordered the sunnen an-30, the heads are at the machine shop being checked and having one of the hoist bracket mounts refabricated
The project continues,
Pretty cool! Would be a very nice score if the pistons fit to bores with correct clearance and rings can be gapped.
Just do the special paste treatment to ensure cylinders are surfaced prepped right and build her up.
+3 on this being interesting avenue for M62ers. Woild be great to put to bed the "can't be honed!" Limitation.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Could this accidentally become the TT boostmaster block of the future?
Stay tuned kids.
More hi-tech goodies.
https://rennlist.com/forums/924-931-...with-pics.html
Is piston deck height the total length of rod and piston? thats what google shows me, if so I don't have a accurate tool to measure that, tape measure is what I have that size.
I'm assuming these are 4.6 pistons as those are 93mm, these could be some other type, they are shiny inside and out either new or cleaned really well
Block and heads are stamped b44
Take note of this Alpina B46. No markings whatsoever, along with a different finish.
http://www.ebay.de/itm/Motorblock-19...-/371959405865
http://www.ebay.co.uk/itm/BMW-E53-X5...-/201496696423
^somebody in the UK could pick this up, maybe the Triumph guy? He's selling an M6x ITB kit btw.
Does the piston top stick up past the block?
And all 4.6s are cast with 4.4 in the rear water jacket. The i.d. boss gets shaved and restamped.
