Results 1 to 15 of 15
Thread: ZF 5HP30 control cable plug/gland oil leak - new cable harness long ETA, glue fix
    Sep 2014
    Perth, Australia
    '92 740iL + '85 M635CSi
    I've heard a rumour there's a gluing fix for this oil leak when the plug has deteriorated to the point where it lets the trans oil pass through the plug around the electrical connection pins to the outside. Anyone know where the details of that fix are please? I need them desperately.
    Here's the scene under my 740 today.
    5HP30 pan removed
    Male socket harness termination plug side
    Male socket harness termination valve body side
    Went to ZF this afternoon, showed them the photos and asked for advice. They confirmed it's a very common problem on all gearboxes they see over and over again with no solution. The plastic just goes brittle sitting in hot oil for many years and then starts leaking. They have no workshop solution beyond replacing the entire harness cable. They confirmed there is no source for just the plug alone.
    Zero local stock of ZF part number 1055 227 021 + the earlier superceded part number 1055 227 019 as well. Ex-Germany is all they'll tell me and no idea of a lead-time.
    Solenoid plug connectors at the other end of the harness are all so brittle they can't be flexed without breaking, so removal of the harness from the car is not recommended without a replacement on hand ready to go.
    I really need a patch fix solution here to get the car back on the road. The ZF guys tell me this is an extremely common problem amongst all their gearboxes, not just the 5HP30, so I'm wondering if someone in here has done this before and knows what to do or can at least point me in the right direction?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have seen once photos - but cannot remember where - where someone sealed the complete plug side inside the transmission (coming from the valve body) with a kind of liquid epoxy resin = into the back of the plug side with wires + pins in
    place. Did not look professional, but apparently worked.
    A new valve body wire loom you can get cheaper in the U.S., for example here for $135 +shipping http://www.thectsc.com/catalog/5hp30-6.html
    As for the 'glue' I have no idea, you have to find something which is oil/ATF resistant and temperature resistant , call the the makers.
    Solenoid plug connectors usually break, my buddy who makes the trans service just cleans up the broken plastic parts and tells me no problem without that missing plastic.
    Jul 2016
    Chicago, Illinois
    are slow
    Permatex Right Stuff or something similar?
    Will be a pain to get it off.
    Sep 2014
    Perth, Australia
    OK, here's what I did with photos to illustrate. Got the least viscous, long pot-life epoxy resin available applied directly down into the pin sockets with a hypodermic syringe from the local chemist. Then with the sockets filled, we made a collar dam around the location flange out of plasticine (could use anything similar like blu-tack) to block off the four slot holes in the perimeter of the plug collar which are there for no easily apparent reason. With the holes blocked off to retain the resin in the pocket to be filled around the wires we then cut the needle off the syringe and filled the rest of the surrounding void with resin to completely fill and seal the whole area to the wire insulation.
    Obviously there's a lot of cleaning & degreasing required before you go anywhere near the resin. I used lots of brake cleaner, high pressure air, grease & wax remover and finally I used acetone to lightly etch and dissolve the wire insulation making it tacky/sticky to give the resin something to mechanically key with.
    Before any resin with plug set up in hole in workbench with bundling collars cut to allow separation of wires for access with syringe needle.
    Filled with wet, liquid resin with plasticine dam in place around collar under workbench to prevent resin running away through moulding slots.
    End result with resin set rock hard after 24hrs sitting. No shrinkage and set rock solid. Plasticine dam now removed, moulding slots completely blocked with solid resin.
    Here's a photo of the back side with the plug end that extends outside the gearbox to connect to the DME control cable. Here you can see one of the moulding slots in the collar of the plug body that needs to be dammed up with some putty type stuff that won't adhere easily to epoxy resin.
    I have no idea what the slots are for. Maybe they're just part of the plastic moulding process required to make the plug in the first place or perhaps they're required for some reason to allow ATF to splash lubricate the two replaceable O-rings that seal the plug to the hole in the gearbox valve body in which it mounts? I really don't know but they definitely make sealing up the plug harder than it needs to be. With the slots open, you're relying totally on the integrity of the O-rings to hold the oil in the gearbox much more than you are with the slots blocked. The slots provide free passage of oil straight through the plug collar to the O-rings. With the slots blocked, the only oil that will come into contact with the O-rings will be any leakage around the collar and the shoulder of the gearbox flange into which it mounts. If anyone else doing this sees a problem with this and wants to maintain the open slots, then I suggest first blocking them up completely like here and then redrilling passages through the resin blocks to recreate a direct oil path to the O-rings again.
    Personally, I think this looks so much better than the original plug that I'd do the same again to a brand new harness before installation if I had to. I will be absolutely amazed if I have any ATF leak problems from this plug again!
    May 2017
    Kansas
    I wouldn't use resin around the wires. Epoxy resin no way. Cant be removed and potentially problematic to work with in tight spaces.
    Silicone high temperature sealant will do, pretty tough when fully cured, and it is removable without damaging anything else if you ever need to get at the wires for any reason. And you just need to let it set for like 60 minutes before reinstallation, but full strength happens after 24 hours. I've used silicone sealant on the wire spades under my relays which were coming loose, and it has not caused any problems in the last 6 years.
    And this is not gasket sealant. Its the high temp silicone sealant that feels like hard rubber when dry, good to 450 or 500 degrees can't remember.
    May 2017
    Kansas
    Quote Originally Posted by Legoman View Post
    You might still have leaks if you did not use a new o ring, or did not reinforce your old o ring in the following way :
    https://www.bimmerforums.com/forum/s...cheap-and-good
    Well it shouldn't be too difficult to do if you ever have a leak, just pull the socket out an inch and wind some tape around it. Or you could always apply a small bead of the same sealant I was talking about from the outside, just like what this guy did here for a hg mating surface
    https://www.bimmerforums.com/forum/s...#post29732531:
    Sep 2014
    Perth, Australia
    Quote Originally Posted by flying525 View Post
    Not being able to be removed was the whole point. I'm fully aware that this is a very permanent fix. That's exactly how it's intended to be. If the cable or the wires ever fail again, then it will require the purchase of a whole new harness to repair in most likelihood. Anything less than a permanent solution opens the door to fragments of silicon or whatever else you try to seal it with, breaking off or falling off the plug and circulating through the valve body with the oil. That scenario will have far more expensive and permanent ramifications than needing to buy a new plug harness!! Epoxy resin will not without considerable mechanical attack ever part company with what it's bonded too. This is a very important consideration when its installed inside an automatic transmission valve body. In any case, the wire pins cannot be serviced or detached from the plug even before being filled with epoxy resin. They are moulded into the plastic of the ABS plug in the manufacture. They have to be because they need to form an oil tight sealing interface between the metal pins and the plastic plug to stop ATF leaking out. This is why ZF can't sell you just the replacement plug alone. There's no way to insert the pins into a new plug. They have to be moulded into it during the manufacture of the complete harness.
    Are these relays constantly flooded in hot ATF oil and situated right next to a valve body with a maze of channels that looks like this, fed by solenoids controlling pin hole sized valves supplying the oil to open and close the clutch packs?
    If not, then I think you might be slightly underestimating the consequences of getting the sealant wrong when working on the inside of an auto valve body.
    Yeah, I wasn't going for hard rubber consistency. Rubber goes soft in oil and deteriorates and then falls apart. I was going for hard as granite and completely impervious.
    Jan 2005
    Japan
    @ flying525: Before you post, READ the problem, try to understand the problem. The problem are not the o-rings, the ATF comes thru the center of the plug around the pins, not outside.
    Epoxy resin is fine, there is no reason to remove it later, this is to stay there forever.
    Sep 2014
    Perth, Australia
    Yeah dude, of course I've got new O-rings to go in. That was the whole start of this exercise in the first place. There was an oil leak at the plug, so I bought the O-rings for pennies. They were a grand total of $5 each. If $10 worth of O-rings had solved my auto trans oil leak problem then I would have considered myself very lucky indeed. Sadly, upon removing the plug it was determined that it was actually leaking through the electrical pin connectors instead of (or perhaps in addition to) past the O-rings. That was where the epoxy-fill solution came in since a new cable was approximately 4 weeks ETA lead-time ex-ZF Germany.
    The old O-rings can be seen lying in the cardboard box in the above photos. They have been cut here because I was using them as reinforcement for holding the plasticine dam in place around the collar of the plug. When the resin had set I just sliced them with a knife to remove the plasticine dam easily without disrupting anything else. They were not going to be reused anyway since I have new ones ready to go in.
    The old O-rings had no elasticity left in them after 25 years. They would stretch open but not spring back again. Completely knackered. New ones are super-tight and I'm told are a very tight fit requiring quite a bit of lubrication to get the plug back into the flange in the valve body.
    May 2017
    Kansas
    Quote Originally Posted by shogun View Post
    @ flying525: Before you post, READ the problem, try to understand the problem. The problem are not the o-rings, the ATF comes thru the center of the plug around the pins, not outside.Epoxy resin is fine, there is no reason to remove it later, this is to stay there forever.
    Shogun, before you criticize, acquaint yourself with the CONCEPT of collateral conversations.
    OP, read your subsequent posts and I take your points about sealant and oil. I personally don't think that's an issue I've never noticed any issues with hot oil and silicone sealant. But I take your points about using epoxy to make it it more rock solid to eliminate even this remote possibility, makes sense. Good fix.
    Jan 2005
    Japan
    Copied from another thread:
    I see. Didn't read that. Didn't read the whole thread...
    If i'm free I will read your thread.....
    If you do not have time to read a whole thread, do not answer, before you had time to read a thread.
    This is not the first time that you comment in threads without reading the whole thread and that is only confusing forum members.
    May 2017
    Kansas
    Copied from another thread:If you do not have time to read a whole thread, do not answer, before you had time to read a thread.This is not the first time that you comment in threads without reading the whole thread and that is only confusing forum members.
    I have replied to this comment in that other thread, where you made the same accusation. Anyone who cares to read can trace it through my post listings.
    OP, I was thinking earlier. Did you consider using clay mix epoxy to plug up the plug? That would be much faster, and equally good if it would work and when soft it can be easily stuffed into the plug around the wires with a thin stick, no need to plug holes on the other side temporarily. Don't get me wrong now. Using resin is a great idea. But would using clay epoxy mix be even better?
    Sep 2014
    Perth, Australia
    I'm afraid I'm not familiar with what clay mix epoxy is but I assume some kind of an epoxy putty or filler used in external wood work repair for things like dry rot? I did not consider using that, no. What we had our minds set on was something as liquid as possible that could be squeezed through a syringe and with as long a pot life as possible without going stupidly light on the hardener. Of concern also was to ensure that epoxy is not electrically conductive. Apparently some types of epoxy are infused with silver + nickel particles to make them conductive, but the one we used was not this kind.
    Whilst avoiding having to dam up the slots would seem an easier method, it's really not that much extra effort to block the holes and you are definitely going to get a better penetration and more complete air bubble free filling with a properly liquid mix than with a putty. The gaps around the wire pin sockets are extremely small. They may look big enough to poke a stick with in my very close range macro photographs, but trust me, they're not. We used a hypodermic needle so fine, I could barely even see it without the use of a magnifying glass.
    Sep 2014
    Perth, Australia
    Just to end this thread, I got the car back yesterday after the repaired cable was fitted. All working perfectly. No leaks anymore. Took about 10 litres of oil to refill the gearbox afterwards, but using United MV-99 at 1/7th the cost of Mobil LT 71141, even that didn't hurt too much.
    My mechanic still expressed concern that the epoxy glue wouldn't be rated for the temperatures the gearbox oil sees because he ran the car on the hoist stationary for a long time checking for leaks and of course with no airflow from moving, it got extremely hot with the exhaust right alongside. We tested the theory by heating the (now solid) spilt epoxy from the filling exercise in the plastic food container we used to contain spills alongside another scrap electrical plug made of the same plastic as the one on the ZF harness cable with the bare flame from a blowtorch.
    The plastic plug started melting within 3 seconds and caught fire after about 10 seconds. The epoxy never melted, but caught fire after what seemed like a long time. I got bored holding the torch, but it might have been half a minute or so. Don't think there's going to be any temperature resistance problems there! If there are, it'll be the plug itself which disintegrates leaving a lump of epoxy clinging to the wires! Come to think of it, the plastic insulation on the wires themselves is probably the least heat resistant of all.
    Jan 2005
    Japan
    Don't worry, the ATF is not boiling. Normal driving will raise fluid temperatures to 80 degrees C., which is the usual temperature range at which most fluids are designed to operate. If fluid temperatures can be held to 80 degrees C., ATF will last almost indefinitely -- say up to 160,000 km. Says a fellow of you from OZ http://www.thetransmissioncentre.com...l-information/
  1. Oil Leak (new owner 95 525i M50TUB25 with VANOS)
    By tristero in forum 1988 - 1996 (E34)
    Last Post: 03-10-2014, 12:20 AM
  2. Oil Leak (new owner 95 525i M50TUB25 with VANOS)
    Last Post: 03-10-2014, 12:16 AM
  3. oil leak from drain plug
    By mastermind in forum 1991 - 1999 (E36)
    Last Post: 10-08-2006, 08:24 PM
  4. m42 oil leak in spark plug chamber
    By Andrew546 in forum 1983 - 1991 (E30)
    Last Post: 04-16-2006, 04:30 PM
  5. M/T Drain Plug Oil Leaks
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2003, 10:31 PM
