Results 1 to 9 of 9
Thread: Can you convert a fully automatic top to a manual top?
    May 2017
    Honea Path,SC,USA
    1999 BMW M3 Cabrio
    Question Can you convert a fully automatic top to a manual top?
    Like the title says I would like to know if its possible to convert my 1999 M3 with the fully automatic top to the manual top with the pull handle like this http://www.ebay.com/itm/BMW-E36-M3-3...-/252509354634 . A little info about the car, I bought my car last year from a guy who said he got it from the original owner who worked at a BMW dealership in California. Now I suspect somewhere along this line the guy I purchased the car from used a drill to manually lower the top and broke the springs that span from driver and passenger side from the central motor that locks the top to the windshield.
    TL : DR- Can I buy http://www.ebay.com/itm/BMW-E36-M3-3...-/252509354634
    to covert my fully automatic top to the less complex manual top with the pull handle.
    Apr 2003
    Maui
    2011 335xi
    My car was supposed to have an automatic top. And then every motor related to it is gone, so it's a manual top. Or maybe I have my info wrong and 97s are manual? There's a switch for the top though.
    May 2017
    Honea Path,SC,USA
    1999 BMW M3 Cabrio
    My current problem is trying to convert the tonneau cover to manual.
    Apr 2008
    Charlotte, N.C.
    1994 325 CI
    The tension straps in my 1994 324 IC failed . The top would not fold in order therefore I disconnected the motors and manually open and close the top. It takes a little effort to lift but is easily a one person job. Just be sure the fabric and headliner are beneath the crossbar when folded to allow the cover to close fully
    Oct 2013
    Portland, OR
    328i,740i,e36 m3 x2,e46
    Quote Originally Posted by haydenmeadows View Post
    I converted mine to full manual. Its pretty simple. For the tonneau cover you should just need the handle/cables/latches and this small box where the handle cable meets the two cables for the latches. The rear panel even has a mark of where to cut out an opening for the handle.
    Sent from my SM-N920T using Tapatalk
    The Netherlands
    DE-spec E36 328i/M3 cab
    You can also keep the tonneau cover electric and just have the roof manual.
    IG:
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Full auto top frames are very different than semi or manual frames. You can remove all the full auto locking mechanism and motor and add the manual handle but you will still have to trim off some of the linkage that remains on the frame. I did this for a customer once. A 5inch grinder will allow you to access the metal linkage without damaging the canvas.
    Oct 2020
    Baja
    1999 323i convertible
    Can you do this conversion? How much and where?
    Dec 2013
    22 doors and 4 tops
    I have all the parts to convert top and tonneau to manual. It's not cheap but if interested you can contact me. I also wrote up a tutorial.
  1. can you convert a semi-auto top to a fully automatic?
    By atotoboy in forum 1991 - 1999 (E36)
    Last Post: 02-18-2013, 05:44 AM
  2. Semi-Auto Top to Semi-Manual Top
    By M3Alpine99 in forum Convertible Questions
    Last Post: 02-21-2011, 09:38 PM
  3. convert an auto-top to a manual-top
    By rdeboer in forum Convertible Questions
    Last Post: 11-05-2010, 04:45 PM
  4. can you convert E30 from 4-lug hubs to 5-lug hubs!?
    By 87'mgodackE30 in forum 1983 - 1991 (E30)
    Last Post: 01-25-2005, 05:29 PM
