Results 1 to 8 of 8
Thread: Idiots guide to connecting an ICOM to inpa/Winkfpt?
    Jul 2002
    PA
    E92 M3 Comp
    OK i've been fighting with this for hours now and ready to give up. I have a factory ICOM and cable, so that not the issue. i downloaded Itool radar but when i try and run it, give me an error message "could not find main class com/nubix/ivm/standsaloneprototyp/main/servicemonitoralternative". changed std:obd to remote in .ini, no deal. Any help would be really appreciated as to what im doing wrong here. thank you.
    Jan 2017
    Republic of Macedonia
    BMW X6 4.0d xDrive
    Connect as MOST_ASYNC_ab625
    Gesendet von meinem HTC 10 mit Tapatalk
    Jul 2004
    Houston, TX
    36 Cylinders
    That's bad advice, because MOST async is for using the MOST connection... The dme he is trying to flash isn't on MOST network.
    Download easyconnect and set remote profile to your ICOM ip and OBD_ab625.
    And of course click the ICOM Lock button in easyconnect.
    Jul 2002
    PA
    E92 M3 Comp
    Everything you guys are saying is over my head. Please like explain it from start to finish as I've never done this before. I brought and Icom home from work and at work in Ista connection manager it lists the ip addy for the Icom so i wrote it down. Don't know if this is locked to it or it changes. Where does one find this easyconnect? Also why am I getting the error message with itool radar?
    Philadelphia, PA
    2005 M3 & 2004 330i
    IP address will probably be different when connected to your own computer or network.
    For IToolRadar, try installing the java runtime environment
    The way I do it is I set the interface type to Remote:base in ediabas.ini (others will work too, but I settled on base). Then I open Remote.ini, and under [Base] I set the IP Address to match the ICOM. Then if you reserve/lock the ICOM, it should work with all the ediabas apps.
    Jul 2002
    PA
    E92 M3 Comp
    Quote Originally Posted by TerraPhantm View Post
    yep, java was the problem. now i can open itoolradar. its late now, project for tomorrow.
    Aug 2012
    france
    330D 245hp 2009
    Quote Originally Posted by nightkrawler View Post
    just copy folder in good place, re-read instructions is very simple
    Jul 2002
    PA
    E92 M3 Comp
    Quote Originally Posted by peko View Post
    A reply 9 months later is very helpful. Great first post pal
  1. Replies: 11
    Last Post: 04-15-2012, 04:56 PM
  2. Need photo or video guide on adding an amplifier to my 97-318i
    By jdmg in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-28-2009, 08:45 PM
  3. Is this all I need to connect an AMP to my factory HU?
    By Daddy MO in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-29-2007, 04:03 PM
  4. OK, I want to connect an Ipod to my car...HELP
    By BMWnoob in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-02-2004, 11:03 AM
