Okay so lemme break this down. My car (and steering wheel) intermittently shake when driving at highway speeds, 50-65 mph. After i pass 80 mph the shaking stops. When im curving on the highway, the shaking also stops. I dont have warped rotars because when i break i have no shaking in the brake pedal.
Things that have been replaced;
Lower control arms assembly
Inner and outer tie rods.
New rear tires, front ones have good tread.
Alignment
End links
My drivers front rim is SLIGHTLY bent...
Does anyone know what could cause intermittent shakes at highway speeds??? Id be alot of help 🤔🤔
Check struts and get your tires road force balanced
have all 4 wheels balanced. shaking at those speeds is typical of unbalanced wheels.
Thank you!! I will place an appointment for wheel balancing 🖒🖒
