Results 1 to 15 of 15
Thread: Zionsville shroud on stock 540i radiator, what am i missing?
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    So, i'm in the middle of installing the zions fan shroud onto the stock radiator. My radiator seemed fine and $700 for their radiator isn't a price i am willing to pay at the moment.
    However once i slid the thing in i realized....i don't really have any way to mount this thing. It seems to rest on the stock plastic mounting feet on the bottom alright but there's nothing to attach it on top?
    There's holes on the radiator but the shroud's edge is totally blank?
    And to make matters worse, how are you supposed to mount the aux air quality sensor? That little shelf it's sitting on is blank aluminum...
    So do i absolutely have to bust out a drill and a drill bit for drilling aluminum and start poking holes in this thing?
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Pretty much. I would recommend using rivets or riv-nuts. Harbor Freight's got you there.
    Time to start drilling. I would recommend the $500 RK Autowerks radiator (it's primarily designed for the M5, but it's a drop-in replacement) way before choosing one of Zionsville's units, which have arrived slowly, warped, and with unnecessary fittings (just ask Stück/Jordan). Give RKA a call to verify fitment.
    As for the air quality sensor, you could mount it with Velcro or similar. I don't remember what I did, TBH.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Huh. I wouldnt rivet, you want to be able to pull the shroud. Just some screws or bolts should be ok.
    The rad attachement isn't huge surprise since you're only getting half their "system" but the flat AUC shelf is kinda boge. Couldn't spec a couple quick cuts in that piece so the sensor mounts like factory!? Weak.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Oct 2012
    Seattle
    88 M3, 03 M Sport Wagon
    For the aux air quality sensor, maybe drill some holes in the shelf to run zip ties through?
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    I agree completely = 6 years ago or so when I was installing mine I looked at the OEM install and duplicated the mounting with several carefully drilled holes. I also decided that just below that area would be a good place to locate the wiring for the electrics for the 2 sped fan... more carefully placed drilled holes and the rest is history...
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
    Mar 2010
    Nice Darth. But what's "Lou" speed?
    2003 M3CicM6 TiAg
    Former:
    Mar 2004
    Tyler, Tx
    Flash distorted the LOW on the right !
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Riv-nuts are removable. https://www.amazon.com/Astro-1427-Ha.../dp/B004KLVJAA
    Nate J.
    Jul 2013
    Worcester, MA
    got the thing in and its running great, i'll put some pictures together of my setup at some point soon to serve as documentation for others
    GN92489
    Jul 2013
    Worcester, MA
    just to confirm, "P0128 BMW - Thermostat Low Coolant Temperature" is the code i should expect to get without the resistor on the thermostat electrical plug right? I haven't actually soldered that plug together yet so i was waiting for some code to appear, and that one did this morning
    GN92489
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Possibly, that code is for low coolant temp, not sure the resistor will do anything for that code.
    What does Test 7 say your KTMP is?
    I'm running 88-92C with a 105C t-stat, a PWM circuit connected to the t-stat heater, and a resistor. No codes.
    Sep 2015
    Mankato, MN
    1999 540i
    The code you get with no resistor is
    P1622 - Map Cooling Thermostat Control Circuit Electrical
    My 88C thermo seems to be getting wonky, so my car is running 82C-85C. A little better than the 78-80C earlier this spring. Got another on order from ECS, but it looks like they're out till July.
    Anyways, I'm running way cooler than normal, and no codes related to that.
    Jul 2013
    Worcester, MA
    update on this particular adventure, i'm now getting a constant coolant level low warning even though the tank is at the proper level (filled about an inch above the chamber the float fits into)
    turns out these e36 coolant level sensors are crappy and like to die a lot, drat :|
    GN92489
    Sep 2015
    Mankato, MN
    1999 540i
    I soldered my level switch to short it out.......... No more "Check Coolant Level" warnings.....
    Jul 2013
    Worcester, MA
    i'd rather have a working sensor to be honest
    although i did use an URO float which isn't oem, but it sounds like even the oem or oe sensors constantly break as well. bummer
    GN92489
  1. Why were 245 rear tires stock over 255 on the M's? What am I missing?
    By Oilburnin in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-20-2014, 02:18 AM
  2. Hoosier rains on stock E46 rims..what size will fit?
    By jknopp44 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-08-2009, 09:42 PM
  3. 225/50-17 on stock 540i wheels fit??? 26.1" Dia
    By m5hoot in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-05-2008, 06:48 PM
  4. what am i missing on my intake
    By Coldsweat in forum 1991 - 1999 (E36)
    Last Post: 07-27-2006, 11:19 AM
  5. Clears on an E36...what am I missing?
    By MCM97 in forum BMW Rides & Events
    Last Post: 10-26-2005, 02:19 PM
