Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: My Intro/ e34 s52 swap
  1. #26
    May 2017
    Austin Tx
    e34 525, s52 1993skyline
    So its been some time since I updated this thread because I've been working one another project but I'm now back on this one full time again. so last I said i couldn't figure out the wiring harness so i sent it off to a local shop here in Austin to do that part for me. It now runs and drives so i opted to start the paint and body aspect of the build so i started with the interior pulled everything out and began to clean it the carpet was nasty i mean this thing was sitting in a field when i found it. I ordered carpet dye and shampooed the thing for hours until it was just clear water coming back out. then prepped it too dye dark grey. it ended up coming out great the color was consistent through out all of it and it complements the black interior much better then the light factory grey it originally was. Then the plan was to have a local interior specialist repair the seats and to just reuse all the old parts but while i was searching for some exterior pieces I came across a company in Denmark that sells used BMW parts. They had a complete m5 interior door panels front and rear seats pretty much everything i would need for the inside of my car. i quickly snatched it up and couldn't wait to have it in my hands. Everythingshowed up in only 3 days i quickly went to work to start installing everything and i still cant believe how much better ti all looks compared to when i bought it.
  2. #27
    May 2017
    Austin Tx
    more pictures
  3. #28
    May 2017
    Perth, Western Australia
    some
    Did you find a factory OEM way to move the battery? Did you find OEM mount points and stuff under your seat and just use OEM cables from wreckers or is it all custom?
    As I've mention earlier I've got an older car with my battery in the engine bay so I need to relocate before even thinking about a turbo (right now I'm thinking if I can't get a m54b30 for a stroker I might go turbo b25 instead). Under my seat is just foam and I'm trying to piece together if there's a tray, what kind of brackets, where the brackets bolt to, venting, cable run etc
  4. #29
    May 2017
    Austin Tx
    Quote Originally Posted by fo3 View Post
    no its all custom but the space is there for the battery the one i have in there currently is from my skyline so I'm going to go get a small battery from battery's plus to get a better fit. but the install is all pretty straight forward just running the cable through the firewall was a pain.
  5. #30
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    What'd you use for carpet dye?
  6. #31
    May 2017
    Austin Tx
    Quote Originally Posted by moroza View Post
    http://americolordyes.com/
    I bought black but it looks dark grey I don't think there is a good solution to dye it black.
  7. #32
    ATX
    Sundry old Grrrrmans
    Quote Originally Posted by Tristan36 View Post
    I would tend to agree. The P.O. of my car used some very expensive stuff, brand name escaping me, and proper prep - but starting with light grey is perhaps always going to prevent a truly black result. I gave up on it and will be installing an M5 dark grey carpet that came in black interior cars.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
  8. #33
    May 2017
    Austin Tx
    Quote Originally Posted by BleedsBlue View Post
    Ya but im still very happy with the way it turned out it looks and feels brand new now and it compliments the interoir very well and it only cost me $54 bucks so I cant complain.
    this weekend i hope to have the exterior ready for paint so i can start to button up this project finally i just cant wait to drive this thing for the first time.
  9. #34
    ATX
    Good! I certainly don't want to discourage
    I would recommend floor mats, as the first areas in my carpet that showed wear and then true color were the "foot traffic" areas.
    - Brent
    www.angry-ass.com
  10. #35
    Jun 2017
    California
    88 325iS, 93 525iT
    Which transmission and driveshaft did you use?
  11. #36
    May 2017
    Austin Tx
    Quote Originally Posted by majorprophet View Post
    I got the transmission from the m3 donor car so i believe its the zf transmission and the drive shaft is the one that came with the car it bolted right up.
    ya i plan on getting a set of floor mats and making them the same color.
  12. #37
    moroza's Avatar
    BFE
    E34T
    I spent about that on many (many) boxes of the cheapest, nastiest permanent black hair dye I could find (Revlon). It worked better than some more expensive (but still permanent, level 3) dye, and turned tan carpets a shade of pretty dark brown. I've yet to find a solution for proper black. Someone with access to a chem supplier might try straight para-phenylenediamine (what makes black hair dye black) and go from there...?
  13. #38
    May 2017
    Austin Tx
  14. #39
    May 2017
    Austin Tx
  15. #40
    Mar 2018
    poland
    e34 m50b20 '95 NV
    ill definately follow this project, looks very good!
  16. #41
    May 2017
    Austin Tx
  17. #42
    May 2017
    Austin Tx
    20180615_125839.jpg20180706_171250.jpg built in subs to the rear deck i still need to build the box under them.
    interior i ordered from Denmark.
  18. #43
    May 2017
    Austin Tx
    Slowly coming along
    Its been a while since ive updated this thread I've been slowly working on getting it bac together and figuring out what is missing/damaged. I did happen to get the lights in today and i felt like installing them. so here are some progress pictures.
    https://imgur.com/a/31Q2Uc5
  19. #44
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    $750 and you get some cool ac schitnzer stuff? Not bad at all. I bought a $400 m20 car, and it has a Zender rear bumper and some weird aftermarket heckblende. I might have to copy your build sometime down the road lol. Can’t wait to see this one wrapped up.
  20. #45
    May 2017
    Austin Tx
    Quote Originally Posted by theBMWbeast View Post
    ya it had the side skirts to but they were in really rough shape so i opted for an oem set.
  21. #46
    Mar 2016
    Spain
    e34 525i
    This build is cool. Keep it up! The small rpunded conector you posted, I think it is from the MAF sensor that the s52 has. Your m20 doesnt have one but it has a AFM which works different. If not, it may be from the O2 sensor. They both have the same rounded shaped connection.
    As for how to plug both rounded big connectors, maybe some guys from the e30 subforum can help you better.
  22. #47
    May 2017
    Austin Tx
    40301250_2326021417438618_8441479730313560064_n.jpgworked on getting it a bit more together over the weekend.
  23. #48
    May 2017
    Austin Tx
    Front end reassembled and a/c charged.
    Blows ice cold now that the r134 conversion is done.
  24. #49
    May 2017
    Austin Tx
    cleaned up the e34 today.
    https://imgur.com/a/EIwj7Yi outside is finally together.
  25. #50
    May 2017
    Austin Tx
    So Its been a while since Ive updated this thread I recently got and installed all new wheel bearing a wheel stud kit Cieka Coilovers and some work replica wheels. Enjoy!!!20191125_173411.jpg20191108_173338.jpg20191126_182351.jpg20191121_185154.jpg20191121_185146.jpg
  1. My Imola Red S52 Swapped 318ti Build in Progress
    By m3mobbin in forum BMW Rides & Events
    Last Post: 01-13-2015, 07:45 PM
  2. '98 M3 Vs '91 e34 S52 swap and others
    By hankthetank94 in forum Kill Stories
    Last Post: 05-23-2013, 06:27 PM
  3. e34 s52 swap...no start
    By JakeB in forum 1988 - 1996 (E34)
    Last Post: 10-15-2009, 05:28 PM
  4. Video: My E30 with S52 swap first start!
    By Mote in forum Engine Conversions
    Last Post: 07-18-2009, 08:21 PM
  5. My 95' M3 S52 swap is now complete, I need a suggestion
    By autowaune in forum 1991 - 1999 (E36)
    Last Post: 11-03-2007, 04:48 AM
