Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
Thread: steering wheel tilt and drivers seat dead no loose connection and new control module
  1. #26
    Jan 2013
    orlando, fl
    2001 BMW 540i 6speed
    Quote Originally Posted by will308 View Post
    Yes, it's under the carpet and sound barrier...seems his car had taken on some water and corroded the connections...
    wow didnt know that but is it in the front or rear carpet area? Also wouldnt that prevent the passenger side from working also if that was messed up? my passenger side is still working
    540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
    Hummer- 35inch MT's, Adventure offroad package.
    check out my video gear
    https://kit.co/Lv5multimedia/mobile-videographer-set-up
    Best Oil hands down for bmw
    https://www.amazon.com/gp/product/B0...1441c0abde2552
  2. #27
    Jul 2016
    Chicago, Illinois
    are slow
    Nah, all kinds of functions are in that fuse panel. It's right under the front passenger footwell.
    It can come in from the rear vapor barriers and cause havoc, I rarely see broken front seals.
  3. #28
    Jan 2013
    orlando, fl
    interesting thanks for the input ill have to check that out today, hopefully maybe its just loose wire, I've checked everything else so hopefully nothing crazy.
    Quote Originally Posted by XAlt View Post
  4. #29
    Mar 2005
    Bel Air, Maryland
    E39 M5, 525..e34 525 x3
    Quote Originally Posted by vien View Post
    Sorry to have not responded sooner..it's under the front passenger's seat...his car had taken on a lot of water. It did not affect the passenger seat.
    ( e34)
    '91 525i calypso/parchment (Big Red)
    '92 525i calypso/parchment ( parts)
    '95 525i alpenweiss/parchment, 5spd( parts)
    ( e39)
    '01 530i Msport susp. anthracite/gray
    '02 525i Msport susp. jet black/sand
    '02 M5 jet black/blk-silverstone
    (e53)
    '06 X5 alpenweiss/truffle brown
  5. #30
    Jan 2012
    San Diego, CA
    too many
    Thank you guys - I am about to delve in to the same issue.
  6. #31
    Jan 2013
    orlando, fl
    i checked and all mine are good so im stuck again
  7. #32
    Mar 2005
    Bel Air, Maryland
    Vein, I'm sorry to hear that didn't clear up your problem. The only other suggestion I have is the K72 relay...Here's the thread about my friend's 525T..
    https://www.bimmerforums.com/forum/s...ight=k72+relay
    ( e34)
    ( e39)
    (e53)
  8. #33
    Jan 2013
    orlando, fl
    thanks this is my last hope lol
  9. #34
    Dec 2008
    Long Island
    528iT
    Funny but I still have this same unresolved issue in my car. I'm tempted to pull the carpet up anyway and just have a look to see what's going on. Mine actually throws codes for steering wheel motor jammed, but I can spin them just fine.
  10. #35
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    In the original post you wrote "new fuses"...but have you gone back since you replaced those fuses to see if they are still intact? If there was a short...they could have blown again. Just a thought since it seems like everything you're trying is going no where.
    Based on the chart below...it would be fuses #13 (30 amp fuse) & #21 (5 amp fuse)...for driver's seat adjustment & steering column adjustment. Check your car's fuse chart to make sure they are the same...and that the fuses you replaced are in the correct location and have the correct amperage.
    Good luck.
  11. #36
    Jan 2013
    orlando, fl
    Herro!! yes i have checked unfortunately its not that or the switch my last hope is the relay mentioned above the k72 relay i havent checked that yet.
    Quote Originally Posted by Qsilver7 View Post
    Good luck.
  12. #37
    Jan 2013
    orlando, fl
    reviving since never figured out the problem until now So FYI tried everything from switch to fuses where its common, narrowed it down to the fuses on the passenger floor board.
  13. #38
    Nov 2014
    Dallas TX
    2018 M2
    Hey vien, any update on this? I'm having the same issue I think. The seat was intermittent not working and now it won't do anything at all, as well as the wheel tilt. I've been out of the country and its basically just sat at my parents not getting used much. This past summer during one of the hurricanes that came through NC they said water got inside and was in the floor board. After reading above about the wiring thats under the passenger seat I think that might be the issue. Do you have to remove the passenger seat to get to the wiring over there? I never thought moving the seat and wheel could be so intricate!
  14. #39
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    My car did this thing you're describing when fuse #13 was out. It looked fine but it was out. Have you tried replacing it just because and see if things works?
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
  15. #40
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by Arkum View Post
    Knock, knock Vien. What up? Got yours fixed?
    No, just unbolt it from the floor and tip it backwards.
    You'll need to remove the kick panel and the door sill to get the carpet pulled up.
    The fuse box is just ahead of the right seat track.
  16. #41
    Jan 2013
    orlando, fl
    Hey Jim, nope havent fixed it yet, i might tackle is this week since im off for once from work.
  17. #42
    Nov 2015
    Forest Grove, OR
    1995 520i
    Hey Vien -
    Any resolution on this? after reading that whole post it's like a book with the last page ripped out, haha!
  18. #43
    Apr 2012
    baytown,texas
    1995,bmw,540i,4door
    Hey Vien
    Ive had the same problem for so long. its been years since ive attempted to fix it. my e34 540i has been sitting for a while ive only recently been rebuilding it. But this problem no one seems to know how to fix it. My seats and my steering wheel will not adjust and my mirrors will not adjust either. its very frustrating. what i did was i put the fuse in that controls the seat and at the same time i had my hand on the seat adjuster and moved the seat so i could fit in the car and then pulled the fuse out so it would not move back into the foward position. thats literally how i have been driving the car. since then the fuse has never been put back in so that when i start the car it does not go back to factory position. that was over 8 years ago. i had this car since i was 15 and it did this when i was 18 or 19 im 27 now and i really want to fix this problem. If anyone has a solution please do share. i will mess with my car later and see what i can do.
  19. #44
    Oct 2020
    Pato Branco, PR, Brasil
    1997 528i E39
    Heey guys, I know there's a long time since this thread came out, but I have one similar unsolved problem, and I have no idea what is going on. So, the steering wheel is not moving, seats works fine, fuses are ok, I do have 12v on the steering wheel motors. Last time it worked was when I was trying to check if the motors works and I pressed the memory button, it was the last time. I can get it to work anymore, I searched all the internet for someone with similar problems, but I couldn't find anything.
    Everything else works, mirrors, locks, seat, everything...
  20. #45
    Jan 2013
    orlando, fl
    Quote Originally Posted by lethy View Post
    I still to this day have not solved the problem lol, new fuse box and relays also. SO im going manual seats.
  21. #46
    Jan 2014
    Have you replaced the seat switch?
    Diehard E39 driver.
  1. Replies: 3
    Last Post: 07-02-2015, 06:00 PM
  2. 97 540i steering wheel and drivers seat control
    By robertgu in forum 1996 - 2003 (E39)
    Last Post: 04-03-2014, 12:58 PM
  3. Replies: 8
    Last Post: 12-18-2012, 01:08 AM
  4. airbag light and drivers seat/steering wheel not working..
    By uvacarbuff in forum 1996 - 2003 (E39)
    Last Post: 05-31-2010, 04:54 PM
  5. Replies: 10
    Last Post: 02-13-2010, 09:06 AM
