Hey chaps. This is the 2nd time I've got the e8 heat error message. Then after a while the E2 message comes up. I'm running a Bosch sensor. I've got it wired with a really to the fuel pump so it's only on when the engine is running and I've also installed the thick weld in exhaust bung.
Is it a wiring issue not being enough capacity to run the heater element or is it a heat issue itself.
Please help. Never had such issues with my ugo sensor
BMW’s
90 E34 M5
84 E24 M635csi standalone ecu with coil on plug
94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
97 Z3 2.8
97 E36 M3 euro SC still u/c
OTHERS
11 Audi S5 APR stg2
19 Volkswagen Amarok V6
I think innovate determines sensors are no good sooner than other brands. I probably won't buy another innovate. Had 2 and they require new sensors too often. But try an extender heat sink if you want or relocate the 02.
I wouldnt be wiring it to the fuel pump because you want the o2 to come on when the key is on, not when the pump/engine are running
And save your self the hassel and just buy an AEM gauge. Cheap and easy to wire.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
It's wired to the fuel pump as sometimes the car could sit with te ignition on without running which I would have thought would stop the issue of the heater running for periods without the engine on
BMW’s
90 E34 M5
97 Z3 2.8
OTHERS
11 Audi S5 APR stg2
Most likely the sensor, try recalibrating but if it comes back then sensor is probably doneso in the innovates eyes. We've used lots of innovates the lc-2 gave us the most trouble and just starting to have problems with an mtxl but its holding out. I'll keep running mine until it starts acting up. Their QC seems to be fickle
