hi i am in the process of replacing my plugs on a 328is 1997. I got the coils and everything out, except that my plugs do not want to come out. i am using the special socket and have all of the tools needed but they still dont want to come out. should i force it to make it come out or what should i do?
THanks
That dont make sense. I use a socket that has the rubber grip inside it to grab the plugs out. Did you loosen/un-screw the plugs all the way? Maybe a hair of the plug thread is hanging on. I dont know, thats weird. Good luck.
Do you mean that you can't unscrew the plug (they're in too tight/corroded) or that you unscrew them all the way, they're loose, but won't come out of the hole?
-Bungy.
1999 323ti
2005 530i 6-speed
2020 X5
2013 Mini Cooper S
i meant that they were too tight, but i already fixed the problem..thanks for the help
