i change starter conect everithing in order but when i turn key on nothing only click from starter....there are three wires on starter one big red with nonstop+, and two small.one of small wire has no power when i turn key on and i know it must be power or 12 volt in bolt of small wires when you turn the ignition key to start the engine...so EWS problem or else....batery is new.
Sent from my Elephone P8000 using Tapatalk
What is the battery voltage?
not EWS. car would still crank. did you clean off wires before attaching to starter? single click means starter solenoid is firing but that there is not enough amps to turn starter motor.
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
Which small wire? Can you circle it in a picture or diagram?
the smallest green attach to the top of starter in that wire no power when turn key on
that is the starter wire - it will only have power when the start button is pushed or key turned.
It looks like the other terminal (the cable eyelet) needs to be sanded a bit .
... and the nut installed!
Likely either a bad wire/connection in between the ignition and the 'signal wire', or, maybe, bad ignition switch if all checks out.
Wiring for the 'signal wire' goes:
Ignition switch -> EWS -> starter
So bad ignition switch contacts inside could be working enough to provide a signal but not delivering the amps and causing the voltage drop.
Very long shot that inside the EWS is a relay failure. But as gmak rightly says, EWS is trying to activate the starter it 'should' be OK. They don't go bad that often.
However I'd start with wires/wiring first. Check the starter signal back to the EWS (does EWS put out a strong 12+ volts at its pin on 'start'?) and if all that wiring checks out, then work back to the ignition switch and if its putting out good voltage.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
i forgot to say,the black small wire you can see attach on the botom of starter has power about 9 or 10 volt and that wire work so lift the small gear inside i hear hard clik sound when start the key , big red have 11,7 volt so its ok ,only small wire dont have power,so my question is did 2 small wires must have power in same time when the start the key???
OK.
11.7 volts is weak. 9-10 volts is super weak. You do'nt have enough battery power in this car.
Black wire is the one that triggers the starter to turn. Black and yellow wire is a return signal to the cluster and the DME that says "car is now actually trying to turn over".
2003 M3CicM6 TiAg
Former:
so if i understand the small black wire is main with power to roll the starter and must have 12 volt when turn the key ,and the small yello black wire has nothing with power or its normal not to have power in this wire when key is on .i try to put direct 12 volt to black wire but norhing ,the same thing only lift somethin inside but not roll....big tnx for answers
The small black is 'starter signal'. It clicks a relay & solenoid inside to start the process. It doesn't provide the main power to turn the starter motor itself. The starter motor power comes from the big red cable but only gets turned on when the small solenoid fully clicks over. The small wire needs enough power to make the solenoid click over, if it doesn't have enough power it'll be like you see - it'll click softly but not fully engage. The real power to turn the motor comes from the big red cable.
Another thing to check is the engine grounds BTW which if they are bad, would cause all connections to be poor.
However: you almost certainly just have a dead battery. 11.7 is very weak as said before and these cars won't generally turn over at that kind of voltage. You said its new - have you charged it up fully? There are various faults that these cars can have that will flatten the battery overnight. Underhood light, shorts / water in the floor, stuff like that.
2003 M3CicM6 TiAg
Former:
update....finaly....the problem was starter,i take out from engine ,open inside the starter clean with some carburator spray,all put back and try direcly with batery...first wont work only big loud click i try couple times and finaly start to roll...i put back on the engine and try same thing couple times click and finaly start rolling the engine .....so starter was main problem tomorow i will change with new one ....voltage was the same as i say but it roll like charm.....SO BIG THANKS to all for help
