Results 1 to 9 of 9
Thread: No thermostat
    Apr 2017
    IE
    Convertible
    No thermostat
    Has anyone driven with no thermostat? Can it work? Ive been trying to identify the overheating problem.
    Sent from my SM-N900T using Tapatalk
    Jan 2017
    Metro Detroit, MI
    98 BMW 323is - 2.8T
    You will have issues warming up and maintain operating temp, but should run fine.
    If you're trying to test the thermostat, put it in boiling water and watch it open. Should give you a good idea of how it's working.
    Sent from my SM-G925V using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Same condition as with a broken, always open t-stat = engine does not come to operating temperature = more engine wear on the long run, more fuel consumption, but basically it is possible.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Quote Originally Posted by #1bimmer325 View Post
    I hope you're not pulling it as a solution.... And I don't see it as being much help diagnosing your problem. If you suspect it's the t-stat causing your problem it's cheap enough to just replace it just because.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by Nanniepoo View Post
    but, super cool for super power bro
    Jun 2010
    NY
    1997 328i
    You can pull the thermostat to test it, but not to solve a overheating problem. You should start with replacing the water pump.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Just install a new thermostat. It isn't worth the trouble to take it out and then put the tstat housing back on without it and then have to take it back off a second time to put a new one in.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Apr 2014
    UK
    1995 BMW 328
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Apr 2017
    IE
    Convertible
    When i installwd the radiator I didnt install the fan right away so i assumed that was the problem just because it was creeping to overheat ing and the gauge would fall back down a couple of time before red lining.
    So thanks for advive and opinions.
  1. No thermostat, always cold?
    By Serge88 in forum 1991 - 1999 (E36)
    Last Post: 12-26-2015, 07:41 PM
  2. NO Thermostat!!
    By bimmerbri2 in forum 1988 - 1996 (E34)
    Last Post: 12-16-2012, 12:31 PM
  3. No thermostat, good or not good?
    By kolo92 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-11-2011, 10:42 PM
  4. 100+ outside temps and no thermostat, good or bad idea?
    By JerryTX in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-09-2010, 09:58 AM
  5. (Used Search) Ok to run with no thermostat?
    By dave5678 in forum 1991 - 1999 (E36)
    Last Post: 06-16-2007, 12:59 PM
