Results 1 to 9 of 9
Thread: Trunk won't open!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Trunk won't open!
    Hi all, 2001 325i auto. 199k miles.
    The PO did not put a lock on the trunk lid. I've been opening my trunk with the fob. All of a sudden the fob won't open the trunk. The car does not have the manual switch to open the trunk. Is there any other way to open the trunk? I want to replace the battery but can't open the trunk.
    Any ideas on how to open the trunk? I have access to the inside of the trunk from the middle of the back seat. The arm rest that folds down has material that is velcroed to the back wall. I can pull down the material and see inside the trunk but the space is too small for me to crawl in there.
    Many advice would be greatly appreciated.
    Thanks!
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by drewusmaximus View Post
    BMW did. Do you not have a lock in the Key hole?
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    No. The car was in an accident a couple of POs ago and the trunk lid was replaced but, they never put a lock in the hole. I've been opening the trunk with the fob since I've owned the car. Now the fob won't unlock the trunk. I replaced the fob battery also.
    Aug 2015
    Cologne, MN
    03 M3 00 740i 98 528i
    Check and see if maybe the linkage rod is laying down by the key hole. Might be able to grab it and pull it sideways to release the decklid
    2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
    1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
    2003 M3 - 210K - BMW Euro Cross Drilled Rotors
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Are you saying that there is a hole where the lock cylinder should be? I happen to have an '01 325i and I just went and had a look in the trunk. Dang, there is no emergency lock release or anything. When I insert the key into the cylinder to unlock the trunk, it does feel like there is something mechanical going on to release the trunk lid, meaning that I don't think there is an actuator involved, although I could be wrong.
    Things like this happening is exactly the reason I keep a cheapie fiber optic camera around. If you can, have a look into the hole. There should be some sort of linkage in there.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    That is correct. There is no cylinder in the hole. There is a rubber grommet covering the hole. I can put my finger in the hole but, can't feel anything mechanical. The PO didn't take the cylinder from the original trunk lid and installed it on the new trunk lid. Does my model have the option to install a manual trunk release button under the dash above the hood release? I've read some models have the trunk release option and some don't.
    Feb 2017
    Metairie, LA
    Shoot, my son just left with the car, but if I recall, turning the key to the left opens the trunk which would lead me to believe that there is linkage that must be pulled to the right. Do you have any sort of magnetic apparatus that you might be able to drop in there to see if you can capture the linkage?
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I don't think I have a magnet strong enough. I haven't tried turning the key to the left on the driver's door. I'll try that.
    Aug 2015
    Cologne, MN
    You might have to get creative with a screw driver or something and see if you can catch it. Being that it ties into the lock cylinder some how, the end of it should be bent in a way that you might be able to get a hold of it with a screw driver maybe....
    Dumb question tho, why are you replacing the battery? Is it dead?
  1. trunk lock actuator locks/unlocks....but trunk won't open
    By SkunkApe in forum 1992 - 1999 M3 (E36)
    Last Post: 11-20-2006, 12:53 AM
  2. Trunk won't open......
    By hinchcliffe in forum 1996 - 2003 (E39)
    Last Post: 03-27-2006, 08:29 AM
  3. Help!!!!!!! My trunk won't open!
    By Jvietstylz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-19-2005, 04:25 PM
  4. Trunk won't open
    By BMWNJ in forum 1991 - 1999 (E36)
    Last Post: 06-16-2004, 11:25 AM
  5. Trunk won't open
    By mgallina in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-14-2004, 06:56 PM
