Hi All,
I am swapping my cracked S52 head for a built M50 head. The only problem is this head is OBD1, and I know if has a different number of temp sensors (and coolant passages?). I am looking for advice on how to "plug" this temp sensor. Any guidance on what I need to do or buy is appreciated.
P.S. This project has been stalled for several years so please excuse any errors in the above statement.
Thank you!
996 Turbo | 1975 TVR 2500m | 1998 M3/4/5 | 2011 Jaguar XFR | 08 R32 | 2013 MV Agusta F4 | 2013 Aprilia Tuono
If you're looking to just block the sensor hole, the threads are M12x1.5. You can find a plug (or bolt) in that thread and put a crush washer on it, done.
That being said, I don't know if the newer temp sensors fit in the M50 head, or even if the M50 head will fit on an S52. My only input is on the thread size.
1993 E36 325is
2003 E46 325iT
SpeedHunters feature: http://www.speedhunters.com/2018/04/...t-dtm-tribute/
APEX feature: https://www.apexraceparts.com/blog/m...-arc-8-wheels/
Use a hex socket cap screw like the oem ones found elsewhere on the engine.
Be smart and get an after market temp gauge. Use the extra hole to your advantage.
Either add a water temp gauge sender or use an oil drain plug with a new crush washer. That will be better than a bolt or socket head cap screw which are not designed to center the crush washer. The OE drain plug is m12x1.5. Check though because the sensor ports might be m14x1.5, the only one I know for sure is m12 is the nipple for the TB heater hose connection.
'94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
'93 325is Coupe, Schwarz, work beater 299k
'89 325i Vert, Alpine White: 5spd swapped. Sold
'04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
'05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
'85 Toyota LandCruiser: Lifted, gas hog. 205k
If you're looking for an aftermarket temp gauge, I just installed this one: https://www.summitracing.com/parts/VDO-A2C59517248S
Works perfectly. Make sure to get a matching 250F gauge. VDO sells one other water temp gauge with the same thread- that is a 300F sender and won't work.
1993 E36 325is
2003 E46 325iT
