Results 1 to 8 of 8
Thread: Spacing E36 subframe down
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Guys,
    I need to space my subframe down a bit to gain clearence from the tunnel to the driveshaft.
    The e90 bolts, how much longer are they then the studs? With the combo of bushings i have now, the studs are just barley long enough so before i go buying the e90 bolts, i want to confirm they are considerably longer then the stud.
    If not, ill source a bolt, but kind of need a starting point.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    poconos pa
    e36 m3, turbo e36
    bolts for e90 are m12x127. I dont see a length listed for e36 studs but the e36 bolts are m12x116.
    -sold...replaced by turbo e36
    Aug 2012
    CT
    I think people are using the front subframe bolts which are 145mm.
    Assuming the the stock rear bolts have enough thread engagement, that would make them about an inch longer. Which would work well.
    Apr 2006
    Minnesota eh?
    86 325es
    McMaster Carr, any bolt you want.
    Aug 2012
    CT
    Exactly what i though, except i cant find ANY m12x1.5 lol
    I got some 150mm 10.9s coming from Fastenal. I figured id get them longer and if they are too long i can add a washer or 2 or cut them down.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Take a 1/4 inch long drill bit, remove bolt, drill through bushing hole through trunk floor. Take 1-1.5 inch metal hole saw, use hole through floor as pilot, drill out the thin sheet metal floor, and you will see the subframe threaded receivers. If not fully tapped, tap them m12x1.5 from the trunk. Practice threading bolt from above and then install from below. Any extra length will just stick through. Weld up some reinforcing if you want, maybe a bar across the bottom tied into some verticals tied into a rear strut brace.
    Apr 2002
    Shelby Twp, MI
    TurboVert, MCoupe, 335xi
    I drew up a set of solid sub-frame bushings and made them extend further on the top side, but put a deeper countersink on the bottom side. This way I could use the stock bolts/nuts. I'm not sure if that's an option for you.
    I lowered the subframe about 11mm and I have a 3.5" aluminum driveshaft with enough clearance. It's still tight, but 1/8" clearance is all you should need if the rear end is solid mounted.
    Aug 2012
    CT
    Quote Originally Posted by EMC View Post
    What would a guy have to do to get a step file of those puppies? or maybe even a real set?
  1. E36 e36 subframe
    By xdougiex in forum Drivetrain & Transmission Parts
    Last Post: 07-15-2013, 12:04 PM
  2. E36 FS: E36 Subframe & Swaybar Reinforcement Kits from UUC Motorwerks
    By zardano in forum Suspensions, Springs & Shocks
    Last Post: 03-19-2013, 01:06 PM
  3. E36 BUSHINGS E36 subframe/diff/rta
    By mrgreengenes in forum Drivetrain & Transmission Parts
    Last Post: 12-30-2012, 05:06 PM
  4. E36 NEW powerflex e36 subframe bushings
    By conway in forum Suspensions, Springs & Shocks
    Last Post: 08-19-2011, 09:52 PM
  5. E36 U U C E36 Subframe Bushings - Brake Lines
    By kimber in forum Suspensions, Springs & Shocks
    Last Post: 09-07-2010, 02:35 AM
