Results 1 to 22 of 22
Thread: First N52 Swap - 1997 AlaskaBlau E36 318ti N52 6Spd
    Jan 2002
    York, PA / NYC Manhattan
    72 2002tii, 87 300 SDL, 91 M5, 95 M3 LTW
    First, allow me to take a few moments to thanks everyone involved in this project and explain why we decided to pursue this endeavor. First off thank you to Mr. C for finding the chassis on Craigslist whilst searching for BMW motorcycles. Thankfully the seller included the keyword "motorcycle" as he was open to trades. We probably wouldn't have stumbled on the 318it (sic) if it wasn't for the trade opportunity keyword. The 3 main players to actually perform the work were: Kassel Performance in York, PA, BimmerBuddies in Middletown, PA, and Chris S. of BimmerLabs in WA. All 3 were critical in actually taking the idea of swapping the N52 into the E36 318ti shell.
    How it all happened: As previously mentioned we found the shell on CL with 50k original miles. It was a factory Alaska Blue MTech automatic with an overheated M44. This presented an ideal shell for our project. We considered intially swapping an S52, S54, N54, N20, but the N52 prevailed for several reasons. Number one, it was going to be a challenge. To our knowledge no one has successfully run the N52 in any other chassis than it was originally designed to be in, while utilizing the stock ECU and no other associated modules. Aside from the electronics, the electric water pump, power steering, 6speed, etc, all posed new hurdles to overcome. The following post will help to describe the process and I will do my best to answer any questions.
    The second reason to swap the N52 was for efficiencies. The 318ti represented efficiency. It was an affordable, practical, light, nimble, spacious compact and we intended to maintain this factory feel only with a modern drivetrain. The aluminum/magnesium N52 actually weighs less than the iron block M44 that was pulled from the shell. The electric water pump removes parasitic loss from turning the belt driven pump on the M44. The new alternator has a clutch design intended for again less parasitic draw and better overall MPG. In stock form the N52B30 makes a healthy 231HP and is rated at 29MPG on the highway. Our power goals were quite higher than the stock 325 output and we were able to achieve nearly a 70HP gain due to hardware and software changes.
    On to the actual specifics of the swap!
    Vehicle started as a 1997 AlaskaBlau Mtech - Auto. Purchased with a bad M44 and wanted to build something unique.
    We started searching for a drivetrain and landed on a 2006 Z4 3.0si The full car was purchased as we thought it would be ideal to have the entire car so we could utilize as much or little as we needed. The Z4 was purchased as a base as it is more similar to the E46 which is similar to the E36.
    Entire drivetrain was pulled from Z4 to start:
    N52 without beauty cover on stand. Now was a good time to replace valve cover gasket, spark plugs, coils, headers, ccv components, oil pan gasket, etc. The E90 power steering pump, idler, and belts were installed as well since the Z4 uses the servotronic steering:
    After removing the engine from the stand, we decided to use a new single mass flywheel conversion from Valeo along with a sprung clutch disc. The original flywheel had some unwanted play in it and though it would be a good idea to replace. We wanted to use the 6 speed manual, so we bolted the 6 speed to the engine and carefully lowered the assembly into the ti. It was a very tight fit with the transmission attached but it did indeed clear without any contact to the body.
    The engine nestled into the E36 bay very nicely. We wanted it to sit as close to the firewall as possible so we ran stock mounts rotated 180 degrees onto the Z4 engine arms. A transmission bracket kit was fabbed for the 6 speed and can now be purchased from Kassel Performance. The stock 318ti rear driveshaft was used along with a stock front Z4 auto shaft and guibo. In the photos below, a stock 6 cylinder airbox was mocked up and later replaced with a modified version of the Z4 airbox.
    Mechanically, this pretty much sums up the actual fitting of the drivetrain into the ti: N52, new stock motor mounts rotate 180 degrees, stock 6 speed transmission, ti rear portion of driveshaft with Z4 auto front half. The small case diff was also changed out for a built 3.46 with the Thayer 3 clutch pack kit. New finned MZ3 cover was installed as well.
    Moving onto hydraulic things. As mentioned above, the Valeo SMF kit was used. A custom short shifter from and clutch line were supplied by Rogue Engineering. Manual pedal box and new OE hard lines were installed from a manual 318ti. E36 M3 clutch master and E90 330 slave cylinders were used. A new larger bore E36 M3 brake master was also installed. One of the brake line fittings needed to be switched at the brake master to accommodate the M3 part. We used a new fitting and re-flared the line.
    The brakes were upgraded to E46 M3 front calipers and rotors. The caliper brackets were machined in order to be a direct bolt on to the E36 318 front hub. No other modifications were required to the front brakes other than longer lines and new Akebono pads. The rear brakes were upgraded to Z4 calipers and rotors. All brake components were sent out to Renewed Finishes in PA for a full rebuild and powder coat. The M3 brakes fitting nicely under stock 17" M Contours:
    Steering. We used the E90 330 steering pump, idler, and belt. The Z4 did not have a belt driven pump. New E36 328i lines were used along with new power steering reservoir. Everything was mounted to existing tabs on the chassis. Easy enough.
    Cooling. The cooling system required some thought. An E36 M3 radiator was used in the stock location. In order to keep the rad as close to the support as possible, the rubber inserts in the mounts were not used. (The fit from the crank hub to the radiator is very tight.) A Z3 expansion tank was mounted where the existing windshield washer reservoir was on the 318 and a bracket was made to hold the expansion tank. The front lower hose from the expansion tank was capped. An E90 manual xi crossover tube was used. The lower radiator hose consisted of modifying the lower Z4 radiator hose. The upper radiator hose was a bit tricky. We cut up a new 630 N52 upper hose. Mainly we needed the quick connect fitting at the top of the engine. This fitting was used as it also had a lower fitting that would supply hot coolant to the heater core. Z4 heater core lines were used along with a random other bit of line that we needed to get back to the Z3 expansion tank. Image of cooling system on N52 to show the flow and electric water pump:
    The Z4 ECU controlled electric fan was then used. The upper bracket portion needed to be lightly trimmed as it made contact with the small factory oil cooler. *The engine mounted oil-to water heat exchanger is very much optional and is not required. The fan was wired per the E90/Z4 and is controlled via the ECU.
    Fueling. The stock fuel pump was replaced by a drop in Walbro 255 provided by Kassel. The machined sleeve is manufactured to drop into the stock hanger with no modification. An E46 M3 S54 fuel pressure regulator and fuel filter were used ad mounted in the stock E36 location. The fuel pressure regulator from the M3 was used as the E90 uses an intank 5bar regulator. The M3 regulator is also has a 5 bar diaphragm and is a return style with a single feed line to the N52. A longer quick connect fuel line from the regulator to the fuel rail was used as the stock E90/Z4 hose was too short.
    Exhaust. We decided to switch out the the stock headers for a set of AA headers. This of course was AFTER the engine was already in the E36 chassis. Not smart. Somehow, the stock headers can be rather easily removed the cat-less AA headers can be installed in the E36 chassis with no real trickery. On top of it all the headers just BARELY clear the E36 frame and fit quite well even though they were not designed for this generation of 3 series. We dodged a bullet on this one. As an aside note, the N52 is a rather loud engine, especially with the aftermarket headers. Much louder than S52, S54 that we are more used to installing. The goals for the exhaust were to keep it 'whisper quiet' until full open throttle. We utilized all 304 SS dual 2.25" piping for the exhaust build. The secondary tubes were kept separate to keep torque up and run into stock secondary catalytic converters from the Z4. They then were merged into an X pipe just before the subframe. We then split the subframe and went into a pair of FlowMaster Super HP-2 mufflers (12412304). Finally we crossed the pipes back around to a custom dual 2.25" inlet to 2.5" outlet SpinTech muffler designed to fit our space and noise constraints. A single 3" stainless tip was used to exit though the factory MTech diffuser.
    Wiring/Electrical: The N52 wiring was not overly difficult. An electronic throttle pedal and associated wiring needed to be added chassis side along with the E90 EKPS (fuel pump relay) wiring. A dual function E36 coolant temperature sensor was mounted in the stock location to feed the signal to both the ECU and cluster. A CAN-BUS controller was built to intercept the check engine light signal, oil level signal, and to control the AC compressor. The N52 does not use a traditional oil dipstick so we wanted a way to monitor oil levels. The CAN-BUS signal is intercepted and converted to a signal for the cluster. The stock 6 cylinder MPG gauge was replaced with a custom dial from E30Dad to display the oil level. The 6 cylinder cluster was also reprogrammed to the stock chassis mileage at the same time by Kassel Performance. Finally the stock MSV70 ECU was flashed to override EWS and all other associated E90/Z4 modules (BimmerLabs/Kassel).
    Gauge by E30Dad:
    Rough Pre-Lim Wiring Chart:
    Power: We upped the stock power via a few performance modifications. The 3 stage intake manifold was used from a 330, Z4 3.0si, X3 si, etc. This is a bolt on modification. The stock headers were removed in favor of the AA headers as pictured above. We also used CobraMarty's machined Valvetronic shims. All of this coupled with dyno tuning resulted in a substantial HP gain. Car will be back on the dyno this Spring for final conclusive numbers.
    Thanks to: Kassel Performance, BimmerBuddies, BimmerLabs, Rogue Engineering, Active Autowerke, Thayer Diffs, Renewed Finishes, UrbanWerks.
    A few other neat little details worth discussing.
    The factory E36 X-Brace fit and cleared the N52 with no modification. It was close, but did clear by a few MM's. A Motion Motorsport underpanel was used to improve aero and add some rigidity to the bumper. E36 M3 OE front bumper lip was added to protect the factory bumper paint. In the event of any front end scraping, the lip can easily be replaced.
    A Lithium Ion battery was re-located to the trunk area where the spare tire tools are located. The new battery weighs under 2kg and we have about 1,500 miles of testing on it. No issues with extended periods of sitting or cold starts. Battery used was: WPS Featherweight Lithium Battery HJ51913-FP-IL. Non ti E36 power cables were used to route through the cabin to the battery junction box.
    You may have noticed that there isn't a visible washer fluid reservoir. The E36 M3 SMG Euro windshield washer reservoir setup was used in this case. We used the Euro rad cover and all factory OE BMW parts to relocate the reservoir behind the bumper. Photos attached although they are NOT my photos:
    WANTED: 18" BBS RCj's
    Oct 2003
    Seattle
    99 M3
    WoW!!! That looks like a lot of work!!! Nice job!!
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    Wow, great work! In for videos!
    Buffalo, NY
    2001 BMW 540i/6
    The definition of OEM+. Curious to see some performance figures.
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
    Jan 2016
    holy land
    1998 e36 323i
    Wow. Very nice and clean swap.
    Are there any videos?
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    I had no idea this existed. Thanks for sharing and nice build.
    Tipsy
    Quote Originally Posted by 95///M3 View Post
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Nice nice nice
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Vancouver, BC Ca
    1993 325is
    What were the dyno numbers?
    Jul 2017
    NEW JOISEY
    e30
    My god is this a clean car good job man
    Jan 2002
    Spent a few hours on the dyno. Tune is not yet finished. Will require a few more hours to really dial in the VANOS. Baseline is a mild 91 octane tune. Kassel tune is the solid line.
    Amazing. Due to the lightweight nature of the engine and amazing power delivery curve I've always thought the N52 would be cool to swap into an E36 (cooler than an N54 or S54 IMHO!).
    Can't wait to see some videos!
    PRICE CUT on ALL FABRICS
    Jul 2010
    San Francisco
    03 530i/5, e30 s52(Sold)
    Awesome swap. What exact performance mods did you to increase the horsepower?
    Oct 2012
    Toronto & Amherst, NY
    96 LS1 328is, 06 330i
    Very very clean. N52 is a great engine. I still regret selling my e90 330i
    The Netherlands
    DE-spec E36 328i/M3 cab
    Only just found this. Great job.
    How's it going so far?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Portland, Ore.
    1990 BMW 325is
    This is neat and an impressive amount of work. I've always liked the E36 Compact. Personally though I would have fixed the M44. These cars are hard to find in original clean condition and also it's not true that an N52 weighs less. The N52 is 148 kg (326.3 lbs) and the M44 is 102 kg (224.9 lbs). More weight is also farther into the nose with the 6 cylinder which makes a big difference with handling. An M44 could also be boosted or built up to produce power similar to an N52 if increased power was one of the goals. Don't forget that the S42 in the E36 Super Touring race car was based on the M42/M44 engine and produced up to 310 HP.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    M42/44 is not so easy to get 200+ rwhp from. Grassroots Motorsports recently spent about $8k building one with Metric Mechanic and I think they ended up with around 170 rwhp. You could search fro their Project 318i. M44 has some advantages and disadvantages relative to the M42; what MM built was sort of a hybrid. I am sure more power could be made in race spec, but most of us don’t want a race spec motor that requires race fuel and sacrifices low end power for peak power.
    BMW put 6 cylinder motors in E36 and they are great cars and popular with racers. There is an aluminum block version of the M52 in E36 in Europe and in Z3 in the US that might save 15% weight.
    Aug 2008
    Houston, Tx.
    Didn't Europe get a 323ti? Surely BMW didn't think it was a bad idea to drop in a 6 cylinder in a ti.
    A boosted m42 could reach 280whp or so but how reliable are you at that point?
    NA to reach over 200whp would cost a lot, as menyioned above.
    Nov 2016
    Long Island, NY
    A few
    ^ Exactly. I spent months of research evaluating the 4 cylinder M42 for use in my E36 turbo build (chassis was a 318is). While a good engine and it would be unique to use, I determined that it was simply not a cost effective solution, especially when considering the limited performance gains and lack of aftermarket support.
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by R.Thomas View Post
    This is exactly why I’ve jumped ship and am putting a Honda K20A2 engine with an EFR7163 twin scroll turbo into my 93 325is.
    Jan 2022
    Stafford,VA, USA
    1989 e30 s52T
    Sorry to reopen this thread. but do you have any more in detail description on wiring Im assuming its just reflashed dme for engine but what about from e36 harness how does that work?
    Looking to do this soon Thanks!!!!
    Dec 2005
    UWS near M3 Bus Stop
    E36 E46 E91 F22 all MT
    Quote Originally Posted by WebJr803 View Post
    id also like to hear more feedback on this, beautiful work OP!! i have N51 sitting in my garage for 18months now, time to find it new skin
    Gone but not forgotten
    SGM e46M & LCI SBM X-drive Msport e90 '13 s1K RR
    I N S T A G R A M : @F R A C K 0 1
    Aug 2020
    Canada
    E36 328is
    Thanks for the info on your process! I’m currently picking away at gettin an N52 into my 1992 slicktop coupe. The latest part to arrive was the 2008 3.0 Z4 auto driveshaft and I’m concerned about length. The splines are only interfacing about 1” which I’m not comfortable with. Any information concerning this would be very appreciated
  1. 1990 E30 318i - 1997 E36 318ti M44 Swap
    By E30M44 in forum Engine Conversions
    Last Post: 05-09-2013, 06:13 AM
  2. E36 1997 S52b32 E36 M3 Swap*MOTOR*TRANS
    By e36mbeemer in forum Engines, Performance Parts & Software
    Last Post: 12-25-2012, 10:44 AM
  3. E36 Wtb nj: e36 318ti rear 5 lug swap
    By hookenM in forum BMW Parts Wanted
    Last Post: 08-08-2012, 07:16 PM
  4. E36 1997 BMW E36 M3 with LS1/T56 swap
    By SHhhhh in forum 3 series & Z Series
    Last Post: 11-11-2011, 10:19 PM
  5. Z4 N52 3.0 Into E36 325i
    By YASH1ZN in forum Engine Conversions
    Last Post: 01-09-2008, 08:38 PM
