Results 1 to 6 of 6
Thread: Intermittent radio and turn signal indicator 97 528
    Sep 2015
    Janesville, WI
    2010 3 series, 1997 528
    The turn signal indicator on the dash (both visual and audible) work intermittently, mostly not. I have a similar problem with the radio. When the signals do work, so does the radio???? The outside signals work all the time. 300k on the old beast. Ideas?
    San Jose, CA
    1997 BMW 540i 6 speed
    What is the overnight battery voltage? Also, when the engine is running a 1000 RPM?
    Apr 2015
    United States
    2003 540i6 M-Sport
    Ignition switch probably. Do the visor test and report back.
    Sep 2015
    Janesville, WI
    I did the visor test...no change I also did something I read in another post about disconnecting the battery, touching the two cables together for a short time and leaving the cables off for 20 mins (sounds strange, but so is the problem)...No luck there either (I was wondering if standing on my head and whistling Dixie might help :-)
    San Jose, CA
    Try answering my question.
    Sep 2015
    Janesville, WI
    The issue has been resolved. Although I reported yesterday that none on the suggested (both current and past) fixes worked, one of them must have as a bit later in the day, the signals and the radio began working again. Thanks all
  1. Radio and turn signal and some cluster lights not working
    By dajark in forum 1996 - 2003 (E39)
    Last Post: 07-10-2020, 12:46 AM
  2. Radio and turn signal help
    By Mycheal Blunt in forum 1995 - 2001 (E38)
    Last Post: 08-17-2013, 03:34 PM
  3. No nav/radio or turn signal indicators
    By Ratbike1 in forum 1996 - 2003 (E39)
    Last Post: 10-07-2009, 01:53 PM
  4. X5 Business radio and turn signal went out, help
    By motowrek95 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-04-2008, 09:22 PM
  5. Need help, radio and turn signal relay is not working
    By Kwaaahhh in forum 1996 - 2003 (E39)
    Last Post: 01-21-2007, 07:06 PM
