Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Bmw E38 99 750IL P0170 Problem
  1. #26
    Nov 2016
    Germany
    BMW E38 750IL Facelift
    Update:
    I changed all 4 intake manifold gaskets with new ones.
    Changes both front o2 sensors.
    Replaced 2 fuel injectors with new ones (the old have broke during the work.)
    Changed the Fuel Pump with new one
    Result is still the same P0170 Bank 1 to Lean and during idle the dme set the cel light.
    Anyone a idea what i can do now to solve this incredible Problem?
  2. #27
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    i still have the same problems! did all the same work as you, but i also have P0170. i haven't done fuel filter yet.
    when your car is idling while warmed, and you press the throttle minimally, does your car shake at all? mine idles great but does not run well when i do this.
  3. #28
    Nov 2016
    Germany
    I Have already done the Fuel Filter and the Fuel Pressure Regulator nothing changes.
    My idle is on P warm Bad with vibration
    In D less Vibration but still there.
    When i rev the car little bit its ok just little vibration.
    This Problem is so hard to solve i changed nearly evrything without success.
  4. #29
    Nov 2016
    Germany
    Could a exhaust manifold leak on bank 1 be responsible for this issue?
    And if yes how i could locate this or find it out?
  5. #30
    San Jose, CA
    00 750IL, 01 740IL
    Quote Originally Posted by Cubehacker View Post
    Exhaust leaks can cause lean code due to oxygen gets in the path of the O2 sensor and it see it as "lean" condition.
    Sent from my VS995 using Tapatalk
  6. #31
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If you have INPA you can discover where the likely fault is from the adaptation values - they will inform you of the likelihood of the problem being due to fuel pressure or a vacuum leak - more information here:
    http://www.meeknet.co.uk/E38/Diagnostics.htm
    For instance - this post here:
    https://www.bimmerforums.com/forum/s...0#post29720430
    Shows a high positive Additive Adaptation but small Multiplicative Adaptation - a sure sign of a vacuum leak
  1. Flickering Xenon head lights on a BMW E38 99
    By Mag65 in forum 1995 - 2001 (E38)
    Last Post: 01-10-2015, 03:35 PM
  2. BMW e38 750i / 750iL Wood Trim WTF is wrong with these people?!
    By onerepublic in forum 1995 - 2001 (E38)
    Last Post: 02-02-2010, 10:36 AM
  3. BMW E38 750i 750iL E31 850i LOW MILAGE THROTTLE BODYS
    By dragon850 in forum Engines, Performance Parts & Software
    Last Post: 10-05-2009, 10:30 AM
  4. BMW E38 Mark IV Retrofit Problem
    By Marinoff in forum 1995 - 2001 (E38)
    Last Post: 09-16-2009, 03:26 PM
  5. Oem Bmw E38 99 Style Tail Lights
    By jmiseo2008 in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 04-14-2005, 03:33 PM
