Results 1 to 6 of 6
Thread: Should there be oil here? E36 S50 breather tubes
    Jan 2016
    Johnstown, PA
    1995 BMW M3 Avus/Dove
    I found something I thought was peculiar with my car (95 M3) and was hoping someone here could shed some light on it.
    The car was giving me a bit of a surging idle at times on cold starts, so I decided to clean my idle control valve. I noticed a bit of oil gunk around the connections for the breather tubes at the valve cover, and a lot of oil sludge, even wetness, around where the small breather hose and upper ICV hose plug in at the bottom of the intake manifold:
    so I figured I'd replace the connectors and the hoses as part of the job. When I unplugged the connectors, I found a LOT of oil inside the plugs at the valve cover (pic) and the manifold.
    Valve cover plug:
    My question: Is this normal? If not, what could the cause be? Will replacing the lines and connectors fix the issue? Seems like an awful lot of oil going into the manifold and it's no wonder the ICV was clogged up with all that oil sludge getting in there. I did notice some oil in the #1 spark plug hole, so it's probably time to replace the valve cover gasket, but from my research so far I don't think that should affect this situation.
    Thanks!
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Yes, you will get some oil, as it should be pulling the vapors from the valve cover area back into the intake. Until the advent of the CCV cyclone valve, you will see more oil in the intake, as it is pulling directly from the top of the motor.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2016
    Johnstown, PA
    Thanks for the response! I did a little further digging and it does look like some oil there should be normal, but this seems like an awful lot of it. Anyway, I'll put everything back together with the new parts and run it a while, keep an eye on it, and see how it goes.
    dworthy's Avatar
    Nov 2010
    Well after 20 or so year of build-up, it will seem like a lot. You can take some MAF or intake cleaner, and that will get it out too.
    Darin
    Current:
    Past:
    M-Flight Member
    Jan 2016
    Johnstown, PA
    Well, it's 20 years but only 80k miles.
    One thing I noticed when searching around: there is a baffle inside the cover, right where the breather hose plugs in. ECS has some good detailed pics here: https://c1552172.ssl.cf0.rackcdn.com/262874_x800.jpg and here: https://c1552172.ssl.cf0.rackcdn.com/262876_x800.jpg Any chance the seal around that baffle has failed?
    Yeah, I'm probably just being paranoid.
    Thanks again for the responses!
    dworthy's Avatar
    Nov 2010
    The main reason for the baffle is to keep oil from getting splashed up into the breather area from the camshaft. I really don't think that there is so much of a seal to keep the oil out, as it has to allow the vapors to be pulled in.
    Everybody needs help now and again, even I ask at times on this forum for help.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Should there be oil in the intake manifold?
    By BimmerM3inGA in forum 1992 - 1999 M3 (E36)
    Last Post: 05-21-2007, 03:55 PM
  2. How many plastic pieces should there be under a M3?
    By 1slowM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2004, 06:24 PM
  3. Should there be a 4 door e46 M3?
    By BAVARIAN323i in forum 2001 - 2006 M3 (E46)
    Last Post: 04-20-2003, 03:30 AM
