Looking to buy some summer wheels and looking at what fits best without rubbing or excessive camber massaging etc.
Would like to get at least a 19x9 wheel, square setup.
Any info will help, thanks.
which model and built year? Moved the thread
Sorry, it is 2008 535xi wagon
I really like the Apex ARC8 wheels that I have been running on my 99M3 and 08M3 for 6-7 years. Light and strong. We have an 08 535xit as well, but it runs stock sport package 18x8.5 with 245/40/18 summer and 17s with snows in winter. The 18s are really heavy. Not sure what the E60 offset is or whether Apex has anything that would work.
Which wheels do you have now?
http://www.bmwstylewheels.com/
On the back of your wheels the offset will be stamped. 17x8 ET43's are typical stock wheels.
Then use this site to figure out which offset/widths have the same inner position as your stock ones:
willtheyfit.com
And then use that site to also compare tire sizes so that front and rear have 1% or less difference in rolling diameter.
However, knowing that the roads in Colorado aren't that good, you may want to avoid 19" rims (think potholes damaging the rims) since you'll probably need to run 30/35 profile tires.
Does the E60/61 use a less common hub bore that the OP also needs to match up or use adapters with?
the x-drives come with 43 offset. you can put regular non x-drive offsets without issue. i believe they are 34.
i have 15mm spacers on the front and 20mm spacers on the rear (will go to 25mm) with the stock 43 offset no problems.
G~
E61 Mods: Trailer Hitch/wiring, Cargo cover roller fix, Backup camera, H&R springs, ER charge Pipe, Mishimoto catch can, boost gauge, intake scoop, JB+, CSR Rear Spoiler, Full SAT retrofit.
Coded: legal disclaimer removal in iDrive, auto folding mirrors on lock, turn signals in HUD, fan speed indicator on when in auto, Doors unlock when key removed
E39 Mods: Euro dash conversion, Dinan exhaust, Dinan suspension with Camber kit, 2.81 differential, flappy paddle with double pull M mode activation/deactivation, backup camera, Video playback on Nav computer (iPod Video for video storage and playback), stereo video playback through DSP, MKIV computer, RPA Tire Pressure retrofit, Intravee II iPod integration, Euro armrest, HUD, Parrot BT, voice recognition module, trailer hitch/wiring, rear mounted 10" subwoofer with amplifier, lighted interior door handles, Evans coolant.
