Just replaced the battery for my key fob... whats the best way to seal the key fob securely?
Sugru Moldable Glue SBLK3 Black 3 Pack https://www.amazon.com/dp/B01BFE0KNQ..._Hp3izbNQDDAXG
Moldable to get in to the small space. Trim off the excess before it hardens. Awesome stuff
+1 to this. I used it to seal up my key. Its very easy to work with. Its like putty so you dont need to worry about any kind of mess. Roll it out to a long skinny roll, apply it around the edges and press the other half of the FOB onto it. A little exacto knife around the edge to trim off the excess and it looks perfect. It shouldnt be a problem to cut into if you ever need to replace the battery in the future. Its should certainly be easier than cutting the factory sealant.
Sugru worked remarkably well. Thanks for the recommendation!
$12x2 for an ebay replacement battery (exact replica so no cutting or fussing)
$12 for sugru molding
$36 for a 2 key fob battery replacement. Sure as hell beats $400.
