The project car is dropped low. What would this do to sway bar system? Do i need an adjustable system? Or is it ok as long as the wheels are equal height?
-Oakdizzle
You're going to need shorter, or adjustable sway bar link pins for the front at least...
3" drop is a lot.. You're going to want a very high spring rate to cope with the loss of travel, and your roll centre is going to be too low and handling performance will suffer.
Absinthe makes the tart grow fonder
Alrighty. Thanks for the info. I will have to raise the car. (Actually saves me a bit of rework.) What would you say is the best range for ride height on performance?
-Oakdizzle
Keep your front LCAs horizontal. 12.5"-13" fender to center of wheel.
