RM European Auto Parts
Results 1 to 4 of 4
Thread: E36 Compressor not engaging when AC selector switch pressed
    Montreal, Canada
    92 325i, 95 318ic
    E36 1995 318 convertible Compressor not engaging when AC selector switch pressed.
    So, here's the check list:
    1. Check the a/c R134a coolant. OK
    2. Check the Fuses. OK
    3. Check the Relays. OK
    4. Check the compressor (bypass the compressor relay). OK
    5. Check the pressure switch. OK
    Then I see a small green spot of corrosion on the BLK/GRY wire at the pressure switch. The wire is corroded through.
    Splice the wire at the corroded section and test. OK
    Voila cold air again!!!!
    darkislight
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Check your climate control unit. In my E39 I wasn't able to get the A/C to work until after I swapped the 2003 E39 climate control unit out for a 1998 climate E39 control unit from the scrapyard. Also it sounds stupid but make sure the dial is set to the blue dots and not the red ones.
    Toronto, Canada
    supercharged 97 m3
    Quote Originally Posted by darkislight View Post
    Had ad a similar problem. These older cars start having wires give up, so a good place to look first! Good fix,
    enjoy the A/C
    Insufficient funds...
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    45 low side is too high. 130 high side sucks. Your expansion valve is clogged, the dryer is toast, and the compressor is likely dying. I suggest you replace all of them.
    Proper pressures would be ~30 low side, 200+ high side.
    Chris Powell
    BMWCCA 274412
  1. AC Compressor not engaging
    By laptop4079 in forum 1975 - 1983 (E21)
    Last Post: 09-24-2015, 02:09 AM
  2. AC Compressor not Engaging
    By SOCOPowerMan in forum 1991 - 1999 (E36)
    Last Post: 08-21-2015, 07:15 PM
  3. AC compressor not engaging
    By ElJefe125 in forum 1996 - 2003 (E39)
    Last Post: 08-29-2010, 10:33 PM
  4. AC compressor not engaging!
    By alpinewhite318i in forum 1983 - 1991 (E30)
    Last Post: 07-21-2010, 02:28 PM
  5. Compressor not engaging!!
    By geha13 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-27-2004, 06:54 AM
