This is a set of front/rear bilsteins with Racing Dynamics springs.
I bought this set from Prussian motors (full disclosure) because I wanted to daily drive my e36 and the ISC coilovers were too stiff for daily (I'm selling the ISC set separately). They told me these are in good shape with some surface rust, but I ended up buying a full set of e36 m3 suspension and using that.
So, I'm offering these along with the m3 hats (offset) from the new set I bought, as well as the centered hats that are currently on these. Hats alone are $25 each.
These aren't the prettiest, but they're fully functional.
Super cheap deal at $120+shipping, especially if you're close to Tallahassee.
Thanks for looking!
Evan
I take it these are non-M struts?
correct, they do not have the tab for the sway bars that the m's use right above where the line holder tab is in the middle.
I might be interested in these. Just need some halfway decent parts to get in there for the immediate future. Unfamiliar with the M3 hats, will I need these for install if I have non-m 325? These wont go freight will they?
the M3 hats probably need the offset control arm bushings. These already have non-m hats on them, but are missing a couple of the screws on the hats the ones that go through to the engine compartment and then you put the nut on them to hold them in) so you could knock those bolts off the m hats I'm throwing in.
bump, still available
Evan, I sent you a PM.
Are these still available, and will they fit a e36 convertible?
SOLD thx
