Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Can anyone with a M44 and a multimeter do me a favour?
  1. #26
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Quote Originally Posted by pauliescff View Post
    Dme connected. Correct
    Thank you!
    Now: 1998 E36 318is coupe (supercharged) Past: 1997 E36 318is sedan; 1991 E36 325i sedan; 1994 E36 318is; 1990 E30 318is; 1995 E36 M3; 1990 E30 318is
    My BMW 3 Series Blog | DASC Owners Group on Facebook | Car Magazine Collector | Auto Books and Manuals | 1984 Australian Cannonball Cup
  2. #27
    Nov 2013
    Southeast
    [QUOTE=john318is;29718543]Thank you![/QUOTE
    No problem. Let me know the outcome
  3. #28
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    I've posted back in my other question thread as I don't really know what to do next.
  4. #29
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Pauliscff, any chance of another check?
    * this time DME disconnected
    * this time check on the socket on the DME itself
    * check resistance/ohms between pin 30 and ground (for ground can use the DME casing or pin 55).
    Thank you.
  5. #30
    Oct 2016
    Austria
    e36 323i, M3 3.2
    Quote Originally Posted by john318is View Post
    Thank you.
    i can't quite follow what you guys are doing but i hope that you are aware that you always have to disconnect the computer (DME) before measuring resistance. otherwise you could kill it by measuring resistance.
  6. #31
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Quote Originally Posted by samy01 View Post
    No, I don't believe that is true.
    Measuring resistance on a device that has power might result in an incorrect reading, but not damage.
  7. #32
    Oct 2016
    Austria
    e36 323i, M3 3.2
    umm okay have fun breaking things then
    it will also kill your measuring device when measuring resistance on a wire that has power
  8. #33
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Not meaning to start an argument but just to ensure that correct information is out there...
    What makes you think that a multimeter can cause damage? Do you have any sources to confirm this? Although I worked in electronics for more than 10 years I've just Googled this and can't find anything to suggest I am mistaken.
    This would only be the case with very high voltages. 12V in a car is not going to be an issue.
  9. #34
    Oct 2016
    Austria
    e36 323i, M3 3.2
    it won't kill your dme if you do it once, but if you do it 100 times then the chances are that the electricity which the resistance measuring device sends out can damage the ecu. it's theory, real life is another story of course. i've seen people breaking their dme or ecu like that, and i personally replaced them because of wrong diagnostic work. my brother once broke an ABS sensor that had an integrated ecu/computer which he should have checked with an oscilloscope or a volt meter and not by measuring resistance. why would you even ever measure with the dme connected. any measurement i can think of doesn't include the dme. i would only measure through the harness from the connection where the harness connects to the dme to the sensors connection or whatever you need.
    i just wanted to say it. and if you have 10yrs experience in electronics i think you know what you're doing. let's not argue, i won't interrupt your thread anymore.
  1. Replies: 7
    Last Post: 05-10-2008, 08:51 AM
  2. someone with an e24 and e30 wanna do me a huge favor?
    By SeattleBMW325i in forum 1976 - 1989 (E24)
    Last Post: 07-20-2006, 01:59 PM
  3. Can anyone with a truck from SD drive to OC?
    By billycorgan in forum California sponsored by Avus Autosport
    Last Post: 07-22-2003, 08:39 PM
  4. Can anyone with UUC visionwerks vouch....
    By ///M LIFEŠ in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-19-2002, 03:40 PM
  5. Can anyone with 540 hfm upgrade get me the part number...
    By madsedan in forum 1992 - 1999 M3 (E36)
    Last Post: 09-05-2002, 12:14 PM
