Results 1 to 8 of 8
Thread: Steering Wheel install
    Mar 2017
    Houston
    1986 BMW 635 CSI
    So as part of the odometer gear replacement, the steering column needed to be dropped and the wheel taken off. The issue I'm having is that I can't install the (original) steering wheel properly. It's the original wheel. There is a horrible scraping/grinding noise coming from the steering column when I turn the wheel.
    First the self locking nut, then the wheel, washer, and finally the tightening nut. Installing with the key in the on position to engage the steering lock mechanism. This seems very straight forward but it's not fitting properly.
    Any suggestions? Thanks
    Mar 2017
    Houston
    1986 BMW 635 CSI
    Quote Originally Posted by maf005 View Post
    Any ideas on this one?
    Apr 2008
    Greenwich, CT
    1985 BMW 635csi
    Mine has a spacer and a washer under the self locking nut. Are you missing the spacer (looks like a thick washer)?
    Mar 2017
    Houston
    1986 BMW 635 CSI
    https://www.bmwtechinfo.com/repair/main/631en/index.htm
    Do you know of another resource that diagrams/explains all components of a steering wheel assembly?
    The order of parts on the steering column:
    Spacer (looks like a thick washer), steering wheel, washer, nut. Am I missing something?
    Apr 2008
    Greenwich, CT
    1985 BMW 635csi
    Mar 2017
    Houston
    1986 BMW 635 CSI
    Thank Fernando.
    Yeah that's exactly how mine is assembled. No idea what's wrong still but I can't turn the car at all now
    May 2009
    Camas, WA
    Euro '85 635csi
    If you loosen the nut can you turn the wheel? Maybe it's over torqued.
    Apr 2008
    Greenwich, CT
    1985 BMW 635csi
    If you can't turn the key try removing the wheel and see if the ignition lock works and you can turn on the ignition. If you still can't turn the key, you'll probably need a new lock (tumbler). The ignition switch is behind the lock and is a separate unit. If the key rotates but you don't activate the starter, it could be the switch.
    If removing the wheel corrects the problem, the the problem is with the steering wheel installation or the wheel itself.
    Let us know your findings.
  1. Need HELP with M3 Steering wheel install
    By alberto_mg in forum 1991 - 1999 (E36)
    Last Post: 12-03-2008, 05:11 PM
  2. RAID steering wheel installed!
    By axel in forum 1992 - 1999 M3 (E36)
    Last Post: 08-28-2003, 05:44 PM
  3. aftermarket steering wheel install
    By TYE in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2003, 08:38 AM
  4. 3 Spoke Steering Wheel Installation
    By 10kken in forum 1991 - 1999 (E36)
    Last Post: 01-15-2003, 12:11 PM
  5. Accessory Steering Wheel Instal.
    By Uber328 in forum 1991 - 1999 (E36)
    Last Post: 07-18-2002, 06:50 PM
