Results 1 to 8 of 8
Thread: Idler pully
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    Idler pully
    '98 e39 M62...
    So my serpentine belt went. I thought it was normal wear and tear on the Belt after all it had lasted almost eight years to the day. Upon further inspection, The Idler pulley broke. The bolt is intact but the wheel is gone. Is it just a simple matter of replacing the wheel (pulley?) or, should I be looking for something else? [this is the first time this has happened so this particular DIY is new to me] I will be replacing both belts as well.
    Also, any diagrams I've looked at are unclear to me whether I'm missing a washer or not, so please advise [see attached pics below]
    TIA!
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Dec 2013
    Chicagoland area
    EXOTICS
    Thanks for this. I only need the tensioner wheel [the one that takes a fillister bolt--included above in pics...]
    Does that come by itself, does anybody have a good one they want to part with?
    Dec 2013
    Chicagoland area
    EXOTICS
    Nearest bone-yard.
    Jun 2014
    Bay Area
    2003 525it
    I'm about to change the belt and pulley on my car too, most idler pulley you break right to break it loose, is this the same, or you loosen it like a normal screw?
    Quote Originally Posted by MIKYZZ4 View Post
    Nearest bone-yard.
    Nah. Ended up getting a new assembly [the two pulleys] As this is a first time diy on this, I'm hoping the tensioner is good... Is this indicative of a bad tensioner[s]?
    Dec 2013
    Chicagoland area
    EXOTICS
    Why didn't you purchase the whole belt drive tensioner assembly from my link?
    Piecemeal parts replacement usually leads to more work, costs later.
    If one part/section of an assembly is worn due to age/mileage, the remainder can't be far behind.
    Besides the whole assembly would have had a lifetime warranty from FCP.
    My decision but thanks for your input. I have my reasons. No worries.
  1. Tensioner and Idler Pullies
    By mrnvgtr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-14-2007, 08:10 PM
  2. Should I replace my tensioner and idler pullies?
    By mrnvgtr in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-14-2007, 08:13 AM
  3. Alternator, fuel rail, coil/plug wires and Idler pully from M54 and other various
    By HE53 in forum Engines, Performance Parts & Software
    Last Post: 08-16-2007, 09:37 PM
  4. Idler Pully DYI
    By mtmpow3r in forum 1992 - 1999 M3 (E36)
    Last Post: 08-11-2007, 10:42 PM
  5. Idler pully?
    By Mantic in forum 1992 - 1999 M3 (E36)
    Last Post: 05-06-2004, 09:48 PM
