Results 1 to 3 of 3
Thread: Convertible top binds
    Sep 2016
    Stroudsburg, PA
    2002 325Ci Convertible
    I have a 2002 325Ci convertible. Today when I open the top I heard a strange metal sound, but couldn't figure where it was coming from. When I got home the top won't close all the way. I realized that is was binding on the driver side. The front piston has a "U" joint at the end which is supposed to cradle around a bin. I have attached a picture of the joint so you know where the problem is. I had to unscrew the bottom of the piston and maneuver the "U' joint over the pin. Not sure what the problem is at this point the piston?
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by slabadie View Post
    That is a very common spot for a wiring harness failure. If your's has been repaired, the wiring harness may not be in the channel.
    Sep 2016
    Stroudsburg, PA
    I supposed that it might be the harness, but the issue I am having is the piston "U" joint is not aligned in the correct place anymore.
  1. E36 Glass Rear Window Convert Top Avail?
    By nick95325ic in forum 1991 - 1999 (E36)
    Last Post: 10-29-2006, 01:59 PM
  2. Convertible top won't work...
    By RED_IC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-21-2002, 11:36 AM
  3. Resetting E36 Convertible Top Motors
    By nick95325ic in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-10-2002, 07:29 PM
  4. Convert top adjust???
    By Bones774 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-07-2002, 12:14 PM
  5. Cord in convertible top broke..
    By orangechicken in forum 1991 - 1999 (E36)
    Last Post: 02-16-2002, 12:49 AM
