Results 1 to 15 of 15
Thread: Electrical Issues-Brake Lights and Top
    Nov 2015
    Texas
    2000 BMW Z3
    I've had a couple of electrical issues I want to address and they may all be related. Withing a month or so I had one of my brake lights go out, shortly after they both went out, and now the soft top which ran well and strong doesnt activate when I push the button. Any ideas where I can start diagnosing the problem? There have been heavy rains and there is potential for water to get into my car from the convertible boot because of dripping.
    I have no experience with electrical systems as of yet and all of my problems have been mechanical in nature so far. Any advice would be appreciated.
    Jul 2004
    Houston, TX
    36 Cylinders
    Most likely the brake light switch on the pedal. Easy fix.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    This would be an odd fix since both brake lights didn't stop working at the same time. I would check it though because it may be coincidence that one light burned out and then the brake switch gave up.
    Quote Originally Posted by khammack View Post
    Could have just had a bulb burn out, then the brake switch went out. Brake switch was my first thought as well...
    Quote Originally Posted by gonrico View Post
    PRICE CUT on ALL FABRICS
    Jul 2004
    Houston, TX
    36 Cylinders
    But, it is worth checking the trunk wiring loom for wire damage.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    For soft top to start working, you need to press on brake to engage brake switch, press on the soft top button, and at the same time tilt the front part of the soft top, engaging the microswitch over drivers left shoulder where soft top folds. Seems like your problem most probably is with brake switch, but microswitch is well known for failing too, so check that if your brake lights work and soft top - not.
    Nov 2015
    Texas
    2000 BMW Z3
    Thanks for the advice guys, I'll investigate and update this weekend when I have time.
    Nov 2015
    Texas
    2000 BMW Z3
    So I installed a new switch... problems are unchanged. Maybe the switch is bad so I requested another... All typical symptoms are there... brakes, top, and cruise control. What else could it be???? Hopefully the switch was just bad.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    While I have seen the asian sourced switches sold by the chain autoparts stores fail in a matter of weeks, I can't say I've ever seen one DOA. Make sure you have it adjusted correctly. Don't push the slider in, let the pedal do it. The next step would be putting a test light on things. This should have been the first step; I am not a fan of diagnosing by random parts replacement. The Blue and red wire is for the lights. If that tests good, the most likely juncture is splice X181 in the driver's footwell.
    /.randy
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The brake light switch can be tricky to replace. I have not done it. Simple as it sounds, some people have trouble. I wonder if the destruction of the old switch is necessary. One person bent the bracket in forcibly removing the switch, which is stronger than the bracket, and this caused the new switch to not work properly.
    http://www.bimmerforums.com/forum/sh...6#post28358366
    http://perkornhall.se/Per_Kornhall/Brake_light.html
    https://www.bimmerforums.com/forum/s...5#post25267405
    http://www.bimmerforums.com/forum/sh...6#post28368906
    http://www.nmia.com/~dgnrg/page_25.htm
    BMW MOA 696, BMW CCA 1405
    Dec 2007
    Great Dismal Swamp
    I've changed the switch in many cars. No destruction is necessary. The only tool needed is a coin.
    /.randy
    Oct 2012
    Louisville, KY
    The coin is used to remove the lower panel.
    Nov 2015
    Texas
    2000 BMW Z3
    I swapped the switch and still no fix. Is there a fuse dedicated the brake light or something?
    Oct 2012
    Louisville, KY
    ... All typical symptoms are there... brakes, top, and cruise control...
    Fuse 46 should be brake lights and cruise control. See if that is what your fuse box lid shows.
    Nov 2015
    Texas
    2000 BMW Z3
    Bingo... it was a fuse... it was obviously burned out.
  1. Replies: 3
    Last Post: 04-09-2014, 05:28 AM
  2. Brake Lights and Electrical Issues
    By bimmer1985 in forum 1991 - 1999 (E36)
    Last Post: 03-21-2013, 11:52 PM
  3. Electrical issue: my brake light and turn signal are best buds
    By geezerman402 in forum 1983 - 1991 (E30)
    Last Post: 04-12-2010, 11:15 PM
  4. Brake light and Top liner issues
    By DGarri in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-09-2009, 12:40 PM
  5. Electrical Issues, Brake Light Circuit, Fuel Gage, Windshield Wipers
    By Paul Strefling in forum 1991 - 1999 (E36)
    Last Post: 09-11-2008, 05:47 PM
