eBMWParts
Results 1 to 9 of 9
Thread: KONI Struts E36 (M3/328is) part numbers confusion
    May 2016
    Los Angeles
    2008 BMW 335i Sedan
    Ok, so I understand that the fronts are always a different part number from the rears because they are obviously different parts.
    What I don't understand is why there are to be two different part numbers for seemingly the same front struts. What is the difference between the two??
    The part numbers in question are:
    8741-1272 Sport
    and
    8641-1372 Sport
    Here's a link to the results that show both options when I enter my car info (1997 328is) on the KONI site:
    KONI Struts for 1997 BMW 3-Series
    The 8741-1272 option is more expensive and appears to be only for the 3-series, rather than the M3, whereas the 8641-1372 seem to only be for the M3.
    My confusion is that I thought the struts for the E36 M3 were interchangeable with all E36 3-series. Am I wrong? If so, what is the difference?
    My goal is to upgrade my suspension to get better handling for street driving. I don't need coilovers. I just want a quality set of Konis with either H&R Sport Springs or H&R OE Sport Springs. I realize I'm asking alot here, but which part number should I go with for the KONI fronts? I've already bought the rear KONI 8240-1115 Sport Struts and just need the fronts. All other advice on suspension upgrades will be appreciated, but I'd like to focus on the struts here.
    Thank you!
    Jul 2003
    Texas
    1997 M3/4/A
    M3 are inserts, i believe the 328 is the whole strut
    May 2016
    Los Angeles
    2008 BMW 335i Sedan
    That would explain the price difference, but I don't understand why anyone would want to use the inserts. Just doesn't make sense to me. Thank you for the reply.
    Jul 2003
    Texas
    1997 M3/4/A
    m3 has sway bar tabs on the shocks, 328 has them mounted on the control arms
    Oct 2003
    Seattle
    99 M3
    An insert is less expensive to manufacture than a whole strut. Why the non-M variants are full struts is a mystery. I'd prefer the M units to be full struts as well. Go Bilstein.
    May 2016
    Los Angeles
    2008 BMW 335i Sedan
    So I bought the set of four with the 8741-1272 in the front and have another question:
    Can M3 sway bar end links be used with these without having to weld anything?
    washington dc
    Avus Cosmos Calypso!
    m3 sway links are to be used with the m3 struts with those tabs. If you got non-m struts those tabs would not be there. So, no.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    From the looks of it, 1272 has the tab that will allow you to run longer ///M links.
    Oct 2003
    Seattle
    99 M3
    Not sure about the use of 328 End Links with M3 front Sway/Roll bar. Hope fully the bar geometry is correct and you have the clearances you need.
    Went the other way - M3 struts on a 328 and the bar interfered with the AC compressor, couldn't attach M3 links.
    Typically M3 shocks/struts are valves differently than 328 shocks/struts.
  1. E36 E36 M3 Suspension Parts Used: struts, shocks, Springs, etc... Make Offer!
    By tynwarrior in forum Suspensions, Springs & Shocks
    Last Post: 07-05-2013, 12:06 AM
  2. E36 Fs: koni yellow front shocks/struts, e36 m3
    By alwaysbored786 in forum Suspensions, Springs & Shocks
    Last Post: 06-08-2013, 12:50 AM
  3. E36 front Koni sport e36 m3, 325i, 328i....
    By s14realm3 in forum Suspensions, Springs & Shocks
    Last Post: 03-04-2012, 11:06 PM
  4. E36 E36 M3 / 328is Parts for Sale
    By parker.jim in forum Engines, Performance Parts & Software
    Last Post: 01-14-2011, 02:04 PM
  5. E36 M3 RTABs Part Number?
    By NY98M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-24-2004, 09:02 PM
