Results 1 to 5 of 5
Thread: How to interpret "Rough" tab in INPA
    Jun 2013
    maine
    1999 bmw m3
    Hi folks-I've been playing with INPA on my e36 m3 and came across a tab labeled "Rough". Its a bar chart of each cylinder with different values. Anyone have an idea of what these values mean and if they indicate any issues?
    Jul 2004
    Houston, TX
    36 Cylinders
    They are a calculation based on crankshaft position sensor and how fast the crank spins by, to estimate burn quality.
    They should be close to the middle with a little fluctuation, all at idle.
    If a cylinder is bad, it will be way off.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Bear in mind that if one cylinder is bad, the readings for both the following cylinder and the opposite cylinder in the firing order will also be affected.
    Jun 2013
    maine
    1999 bmw m3
    Thanks. Not sure what you mean by the cylinder is "bad"? Is it a misfire, or is it a fault in the crank sensor?
    Jul 2004
    Houston, TX
    36 Cylinders
    The crank sensor cannot fault on just one cylinder, it's reading from a toothed ring on your crank.
    One cylinder being 'bad' would mean the combustion is poor (even up to a misfire), possibly due to ignition coil/spark plug... or worse: loss of compression in that cylinder.
    The rough test is quite sensitive to poor ignition, showing a change before you even get a code for misfires.
    -Abel
  1. How to do automatic diagnostics for E39 in INPA?
    By E39Only in forum Diagnostic Software
    Last Post: 08-04-2011, 12:33 AM
  2. How to check if 540i HFM is in working order?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 09-29-2002, 11:39 AM
  3. Replies: 0
    Last Post: 07-02-2002, 05:47 AM
  4. NE1 have a how-to guide on keeping the seats in one place?
    By Jon97 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-15-2001, 09:10 PM
  5. How to tell if car has been in an accident....
    By ///MCubed in forum 1992 - 1999 M3 (E36)
    Last Post: 06-22-2001, 03:47 PM
