Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 2 of 2
Thread: ► New Stronger & Lighter SM-10 & FL-5 Wheels by APEX
    California BAY AREA
    e30 M3, 335d
    Last year APEX worked with the community to develop a new and improved track wheel. Over 700 of you took our lengthy survey and we ended up moving forward with both proposals instead of just one. You wanted a wheel that was lighter and stronger than our more recent designs. The SM-10 and FL-5 were developed based on your feedback.
    Both wheels arrive early-mid June 2017, and we’re already working on expanding the number of available sizes.
    Feature Highlights
    • Lighter by 2 lbs. on average vs. EC-7
    • Stronger than all prior designs
    • I” Beam Machining on spokes
    • Revised inner lip design
    • VIA certified in Japan to JWL standard
    • BBK clearance including 380mm kits
    • OEM mounting hardware and stud kit compatible
    • OEM center cap compatible
    • TPMS compatible
    The SM-10 and FL-5 designs are APEX’s first wheels to feature advanced CNC machining that removes material along the sides of every spoke. This creates a stronger and lighter “I” beam spoke design. To get a similar styling cue, many other brands just use aesthetic accent lips on their designs which add material and weight.
    Style is the lowest priority on our list. We prioritize function over form. These wheels keep the superior BBK clearance of our older EC-7 design. Brembo 380mm and other 380mm kits can clear. We beefed up the inner lip by adding extra material, resulting in better protection again bends during serious abuse.
    Like all APEX wheels, these are produced via flow-forming. This process roll forges the barrels, reducing weight and gives the wheel the strength it needs take on the street and the track.
    SM-10 Sizes and Specifications
    The SM-10 combines a straight 10-spoke design with “I” beam machining to produce a lightweight wheel that is a departure from our traditional mesh styles. Multiple face profiles continue to provide superior big brake clearance and maximized concavity for all sizes.
    • 18x8.5” ET35 - 18.4 lbs. - Arriving June
    • 18x9.0” ET30 - 19.5 lbs. - Arriving June
    • 18x9.0” ET42 - 19.3 lbs. - TBD
    • 18x9.5” ET22 - 20.5 lbs. - ETA Q3
    • 18x9.5” ET28 - 20.3 lbs. - Aug/Sept. Dependent on M2 Group Buy
    • 18x9.5” ET35 - 20.0 lbs. - Arriving June
    • 18x9.5” ET43 - 19.9 lbs. - TBD
    • 18x10.0” ET25 - 20.5 lbs. - Arriving June
    • 18x10.0” ET33 - 20.7 lbs. - TBD
    • 18x10.5” ET22 - 21.4 lbs. - ETA Q3
    • 18x10.5” ET40 - 21.2 lbs. - Aug/Sept. Dependent on M2 Group Buy
    • 18x11.0” ET44 - 21.0 lbs. - Arriving June
    Profile 2 Face
    Profile 3 Face
    FL-5 Sizes and Specifications
    The FL-5 takes advantage of Dual Flow Forming plus our newest “I” beam machining technique. Still a one-piece wheel, the Dual Flow Forming strengthens both inner and outer barrels while maximizing front lip depth for each unique width and offset
    • 18x8.5” ET35 - 19.0 lbs. - Arriving June
    • 18x9.0” ET30 - 20.2 lbs. - Arriving June
    • 18x9.0” ET42 - 20.0 lbs. - TBD
    • 18x9.5” ET22 - 20.2 lbs. - Arriving June
    • 18x9.5” ET28 - 20.9 lbs. - Aug/Sept. Dependent on M2 Group Buy
    • 18x9.5” ET35 - 20.5 lbs. - Arriving June
    • 18x9.5” ET43 - 20.4 lbs. - TBD
    • 18x10.0” ET25 - 21.0 lbs. - Arriving June
    • 18x10.0” ET33 - 21.4 lbs. - TBD
    • 18x10.5” ET22 - 21.3 lbs. - Arriving June
    • 18x11.0” ET44 - 21.6 lbs. - TBD
    Medium Lip
    Deep Lip
    Gallery
    Click the images to view more finish options on Flickr
    Feb 2012
    Arizona
    Those FL-5's look so dang good! So many things to save for! Ill definitely keep an eye on these. My dad just bought a set of EC-7s for his mustang and loves them.
    It is kind of hard to tell from the pictures but on the 8.5" and 9.5" FL-5 do the spokes stick out past the lip?
  1. ► APEX | SM-10 Lightweight Track Wheels
    By Eddy@ApexRaceParts in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 05-23-2017, 08:33 PM
  2. 600w amp and 2 10s - factory 6 cd changer
    By neoprelude in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-25-2004, 08:29 AM
  3. FS: 300W amp and 2 10" Pioneer woofers w/enclosure in Atlanta
    By krisko in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 03-02-2004, 11:04 PM
  4. F/S: Car Audio Rockford Fosgate PUNCH 800.2 Amp and 2 10" RF subs
    By 95MMM in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 07-21-2003, 08:53 AM
