Results 1 to 23 of 23
Thread: Rebuilding an M20B25
    Mar 2015
    Boca, Florida
    1986 BMW 325e Sedan
    I did a compression test and 4/6 of the cylinders got ~130, but 2/6 got ~60, the car doesn't accelerate well, and there appears to be a coolant and oil leak from the head gasket, so I am assuming it is blown. The motor has over 210,000k on it and I am not sure when it was rebuilt last. I already started the procedure. Exhaust is off, spark plug wires are out, fuel rail w/ injectors and fpr are out, airbox w/ intake is out, throttle w/ all connections/hoses are out, distributor is out, I disconnected all the radiator hoses. Right now I am trying to loosen the to large nuts holding in the 2 coolant automatic transmission lines. I can't seem to fit locking pliers on their well enough to hit it with a hammer. Does anyone know the wrench size to loosen the two nuts. Thanks.
    Mar 2015
    Boca, Florida
    1986 BMW 325e Sedan
    Wow, 19 hours later and still no reply. Anyways, I was able to remove the transmission cooler lines with locking pliers and a hammer. I also decided to do an a/c delete in the car, considering I don't need it and it was broken; I removed the condenser, compressor, and all of the lines. I am also considering doing a p/s delete. All of my accessory belts are cracked, so I will replace them. I removed the radiator and fan. I removed the 6 13mm bolts on the crankshaft pulley. I am at the stage of removing the large center bolt that is torqued to 300 ft lbs. What are some practical ways to doing that with only hand tools? I read somewhere that positioning the the torque wrench to lay against a piece of wood on the engine bay and cranking the engine will loosen it.
    Aug 2016
    New Brunswick,Canada
    1988 325iC Convertible
    Sometimes you can wait days before you get a reply...it not a chatty kind of place.....
    I think all the bolts are metric and I wish i could help but when it comes to removing engines or the big jobs I wouldn't know what to do..(I need and old parts car to learn on) but give me little stuff that not internal I'm good....
    Like most say Bentley Manual is a must have and looking at Automatic transmission section 10 Page 16 ...It tells me the Ft Lb to install it but not the size .Don't forget to plug the hole so no dirt goes in..
    Also i think you can google Bentley and get the PDF file on line too.
    I wouldn't use a torque wrench to remove a bolts or do you mean a Torx Wrench.....
    Billings, MT
    2013 328i xDrive
    Yeah these forums have really slowed down over the years, which can be irritating.
    The crank bolt is 22mm and the best way to break it loose is with a breaker bar with a long jack handle as a cheater. If you can get 3 or 4 feet of leverage on it you can break it by hand just fine. Using the starter could work as well, but you may also end up breaking teeth off the flywheel or starter gear.
    -Chris
    My e30 build thread/color change here
    Mar 2015
    Boca, Florida
    1986 BMW 325e Sedan
    HELP I NEED A QUICK SIMPLE ANSWER. IS THE CRANKSHAFT 22MM BOLT REGULAR THREADED OR REVERSE THREADED. I bought a corded kobalt impact wrench that has 350ft lbs but it never removed the bolt. What do I do?
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Quote Originally Posted by carmeladam View Post
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Mar 2015
    Boca, Florida
    1986 BMW 325e Sedan
    Awesome, thanks 323i E30. Is it necessary, to remove the crankshaft bolt to remove the head, change the head gasket, replace the water pump, and replace the timing belt? I thought it was, that is why I was going to remove it, but if I don't need to, I won't. I removed the 6 bolts that held on the crankshaft pulley and was able to remove both timing belt covers without removing the crankshaft bolt.
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    nope, no need to remove the bolt unless you want to take front crank seal or intermediate shaft front seal off in which case you need to remove the big bolt and the gear to allow the lower front cover to be removed
    Aug 2016
    I have an 88 325i Any idea if that single bolt in the middle would be a torx bolt or a hex bolt when changing the crank shaft seal..
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    its normally 22mm hex
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    Let me teach you a valuable skill: CLICK HERE
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
    Aug 2016
    Quote Originally Posted by digger View Post
    Wrong bolt crankshaft bolt i was referring to and it's 7mm thanks
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    which bolt is 7mm? i doubt any of them are 7mm anywhere
    Jul 2003
    I dunno
    '90 Ford Tempo
    With the engine out, you can lock the engine by using a strap of metal.
    Drill a hole and bolt the strap to the flywheel using a pressure plate bolt.
    Then you tie down the other end of the strap to the block using a long bolt, some spacers and a nut.
    The torque wrench must never be used to remove fasteners.
    Use a breaker bar and the lower piece of your 2.5 T floor jack , or a suitable length of pipe over the breaker bar.
    You'll have to figger out how to control the block when applying counter clockwise torque to the crank bolt.
    Tip: use gravity.
    m
    Aug 2016
    Yup It's under the rotor...It's where the crankshaft sprocket and seal is .Bentley Content #4 ,page 24 it's a 7mm hex....I found it..
    Billings, MT
    2013 328i xDrive
    Quote Originally Posted by rustneversleeps View Post
    That's the camshaft, not the crankshaft. The hex bolts are not in the middle. The middle bolt that holds the gear is a torx bolt. The two hex bolts hold the seal retainer to the head.
    -Chris
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Why are you rebuilding the motor when you pretty clearly just have a bad head gasket?
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Aug 2016
    Quote Originally Posted by heifetz17 View Post
    YA found today it's a torx bolt,So now i have to buy a set of Torx Bolt Sockets.The bentley says 7mm Hex bolt, now i have to more tools just for one Torx bolt,Damm.
    Also found out My online parts store set me the wrong Alternator belt and it's to short and 3mm to wide ..Damm again.
    Any Idea what size that Torx bolt that is......I wonder if i can get away with using a 10mm socket with stripping it.. Also should mention little different then some if the video's i seen didn't know i had to take two transmission line from the Rad Part 2 tomorrow..
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    you need a torx bit E12 for the camshaft bolt which is M10 thread. the head bolts are E14 despite being M10 as well.....
    i had to drill the old cam bolt out last time someone had the bright idea of using a hex socket on torx head, the head was FUBAR. fortunately the head was not on the car
    Aug 2016
    Well thanks for the info man.So do i buy E12 socket or bit or E14 Bit I'm confused cause it looks like a bolt with a Torx head and seeing that i need A Torx socket or am i saying it worng...Maybe I'm confuse with you mentioning the head bolts is that like a different topic ..Sorry for now understanding correctly..
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    yes, headbolts are unrelated unless you pull the head which is what the OP is doing so though it worth mentioning.
    you'll only need the E12 socket for the cambolt.
    though it is probably best to by a set with multiple sizes there are a couple other sizes elsewhere on the car
    Aug 2016
    well I started my own thread I have to many question and don't want to cludder this guy thread.
    But ya bought the E12 works perfect "thanks Man Digger" took me about 5 pulls before i got it off was scared to strip the Torx bolt or even snap it off then i would have been f**ked..lol.
    Is there a way to change that bolt with different head bolt I did try a 3/8 socket and it fit nice and snug but still was scared to strip it.and this Torx bolt looks like it was remove before but could have been me but then again it was leaking real bad so I'm glad i change it even the o-ring was flat a dry now I'm having a hard time removing the old one with out damaging the housing the holds the seal.
    Maybe change to a hex bolt like some of the other E30's
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    yes, it is a M10x35mm coarse thread bolt grade 10.9. a standard hex will have a head that is too large but a grade 10.9 or 12.9 M10x35mm socket head capscrew should work, still wont use a regular socket.
    ARP sell a hex bolt that will work with standard 12mm socket but it is $$$ as you need to buy a pack of 5
  1. Need info ASAP, whats an M20B25 worth/weigh
    By E30SRPower in forum 1983 - 1991 (E30)
    Last Post: 04-22-2005, 11:22 PM
  2. cost of rebuilding an s50 for turbo.
    By comptechgsr in forum Forced Induction
    Last Post: 02-22-2005, 02:04 AM
  3. Does anyone know how much it would cost to rebuild an e30 m3 engine(s14)?
    By ehlpitel in forum New York / New Jersey / Connecticut
    Last Post: 05-30-2004, 09:51 AM
  4. Rebuilding an M50.
    By devilbones in forum 1991 - 1999 (E36)
    Last Post: 01-03-2004, 01:45 AM
  5. Rebuilding an engine
    By QuestMCoupe in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-20-2001, 12:02 AM
