Results 1 to 6 of 6
    Aug 2014
    Gretna Louisiana US
    2002 BMW X5 3.0i
    occasional cloud of smoke from exhaust 2002 x5 3.0i
    recently my 2002 X5 3.0i (155,000 mi) started emitting a cloud of smoke from the exhaust pipe. It only lasts 3 or 4 seconds and is gone. It does not seem to be burning oil and has done this 4 or 5 time in the last three weeks. It seems to only be in city driving. I have not noticed this at highway speeds. Also no oil leaking and coolant level ok. I only see it through rear-view mirror so am not sure what color but not black probably blueish. Also no codes or computer messages.
    May 2017
    USA
    E90, E46
    Smoke:
    Blue is oil burning
    white is coolant or in extreme cases fuel
    black is fuel
    your crankcase vent valve is maybe going bad or your rings or valve seals are bad.
    let it idle for like 15 minutes then mash the gas and see if you blow a huge cloud. If so you are leaking oil into the combustion camber somehow.
    Aug 2008
    Olathe, Ks.
    2002 M3, 2009 X5 4.8I
    Valve Seals
    If it's the valve seals. One member used some the Lucas engine oil stop and had success with it. I would only use as little as possible with your normal oil.
    DIY_NATION_TH
    https://www.youtube.com/user/fedexboy07/playlists
    Aug 2014
    Gretna Louisiana US
    2002 BMW X5 3.0i
    Thank you it looks white or bluesh white. a couple of time it did it after idiling in park for a few minutes
    Dec 2013
    Chicagoland area
    EXOTICS
    Since you're at 155,000 mi,
    replace CCV and all associated hoses.
    Jan 2016
    Ca
    2001 525it
    Pcv system worn out
  1. Replies: 2
    Last Post: 02-10-2013, 11:35 PM
  2. Replies: 0
    Last Post: 02-29-2012, 04:41 PM
  3. Top culprits of excessive smoke from exhaust...
    By OnTheFence in forum 1996 - 2003 (E39)
    Last Post: 02-21-2012, 03:20 PM
  4. Lots of white smoke from exhaust, but no coolant in the oil.
    By n3rd in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-09-2010, 07:02 PM
  5. Lots of Smoke From Exhaust
    By JLac in forum 1992 - 1999 M3 (E36)
    Last Post: 12-28-2005, 07:53 AM
