Results 1 to 7 of 7
Thread: Rough Idling / Drivetrain Malfunction Error / No Start
    May 2017
    New York, NY
    2011 BMW X3
    Hi all,
    Just joined the forums. Long time lurker. Need advice/help.
    My newly acquired X3 started (2011, 20k miles, family owned) giving me problems after 1 week of driving.
    -Rough idling for about a week.
    -Wouldn't start yesterday
    -Drivetrain Malfunction Error came up
    The car cranks when I click the Start button. At times, it sounds like it's about to start but then dies. I got it towed to the stealership. They charged me $180 diagnostic fee and just recommended a complete tear down and inspection ($2100). The warranty is over. What should I do?
    I've researched similar issues (fuel filter, fuel pump, fuses, etc). Has the dealership already ruled out those options?
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello and welcome to the forum! I would go back to the dealership and get a copy of the error codes; if you're mechanically inclined, I'm sure that fellow members can give you the procedures to fix your X3. I would also consider a different dealership if they charged you money but didn't give you any information on what was wrong/found.
    888.280.7799 | 6am - 5pm PST
    May 2017
    New York, NY
    2011 BMW X3
    Quote Originally Posted by Pelican Parts View Post
    Thanks for the reply. I was able to get the following:
    "1 TECH: 3151
    REQ: NEED TO REMOVE THE VALVE COVER TO VERIFY IF THE VAVLETRONIC SYSTEM IS
    THE ROOT OF THE PROBLEM
    Cylinder Head Cover Gaskets - Replace
    CAN NOT VERIFY ANY OTHER PROBLEM UNTIL I CAN DRIVE VEHICLE
    CAR CANT NOT START HAVE TO DEAL WITH THWE VALVETRONIC SYSTEM FIRST
    9 CODES RELATED TO THE VALVETRONIC SYSTEM 133010 MALFUNCTION,133011
    SUPPY VOLTAGE MALFUNCTION 135401 OVERLOAD,135608 NO
    MOVEMENT,135808,135A08 135B10,135B11,1F0904 3:13"
    i'm decent with cars but unfortunately I have 0 tools since I just moved into a small apt. If i was home, I would definitely be doing some of these things myself.
    May 2012
    rowlett, tx
    96 Z3, 2011 328, 2011 x3
    Did you ever get a resolution? My car started to do the same thing today
    Quote Originally Posted by precisionintime View Post
    Hi all,
    I'm going to make a few assumptions. Car is averaging 3k a year. I would drain the fuel and filter, because it's easy and that might be a problem. Change the oil beforehand. Check all electrical connections and begin with a full change. Low voltage and BMW don't get along.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Using Tapatalk
    Tampa, FL
    '06 BMW X3
    Cylinder head cover gasket makes no sense. I assume it's the valve cover gasket.
    I'd also check the battery since it's been setting. Also check the ground straps under the car for corrosion.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    If you go to the z3 forum and search for the diagnostic thread started by 328power04 you will find the software and links to order cables to put together a laptop to read codes and reset. Abel is very helpful with getting it setup too
  1. rough idle, white smoke on cold starts
    By jrobie79 in forum 1983 - 1991 (E30)
    Last Post: 05-03-2013, 02:31 PM
  2. Rough idle n power loss. No codes
    By Jaynkay1 in forum 1996 - 2003 (E39)
    Last Post: 07-29-2012, 01:09 AM
  3. Rough Idle/Engines Dies on Cold Start
    By showtimes2 in forum 1991 - 1999 (E36)
    Last Post: 08-27-2011, 08:25 PM
  4. Help Needed: Rough idle and mis-fire, no CEL
    By XTNSIV in forum 1992 - 1999 M3 (E36)
    Last Post: 05-13-2010, 01:27 AM
  5. Rough Idle (30 sec) on Cold Start?
    By Miguel Sanchez in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-29-2003, 04:47 PM
