Results 1 to 13 of 13
Thread: New to me 86 745i
    Portland, OR
    74 e9, 67 2000, 04 330ci
    New to me 86 745i Upated!
    Hi,
    I acquired a 1986 745i executive a couple of weeks ago. Well maintained by 13 year Previuos owner. Aftermarket Garret turbo with wastegate installed with 3" magnaflow exhaust and K&N type intake installed PO. So I have some learning to do regarding turbos. This is the third e23 I've owned but the first turbo.
    Everything seems to work fine, but why do my directionals blink really fast? I've checked all the bulbs, all are working. Also, only one headlight works unless I turn the fog lights then both headlights come on. Hi beams work fine. I have a feeling some wiring was hacked when the car was federalized.
    Oh, the wheels. Not e36 wheels. Some kind of knock off set. 17" et20 so no spacers needed.
    Planning to drive it to The Vintage in NC this weekend.
    Wish me luck.
    John
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Looks good, congrats.
    Feb 2002
    The Dirty Dime
    95 S50 525T;85 QTR til 8
    Fast blink is usually a bad ground. Look forward to seeing this at Vintage.
    1989 635CSi Alpinewieß
    1989 325iC Alpineweiß II
    1985 745i Cosmosblau / Pacificblau cloth
    1995 525iT S50 / 5 speed Alpineweiß III
    1985 635i Cosmosblau
    1998.5 M3 Technoviolent
    1990 325iC
    1999 528i
    Jan 2003
    Bay Area, Ca.
    94 M5T
    i commented on the wheels on Facebook, they look good on the e23. Makes sense that they're aftermarket now, with the correct offset.
    Car looks good, look forward to more pics.
    Mike
    93 M5 3.8 Sterling Silver/Black (euro)
    94 M5 Touring Madeiraschwarz/Black
    80 745i (project)
    83 735i / 5 speed (euro)
    86 745i
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Glad to see that car here. A few of us saw the thing on ebay.
    Pictures of the upgrades would be fun to see.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Portland, OR
    Quote Originally Posted by Hit Man X View Post
    Yes. Not the best eBay listing and the car was in storage so I couldn't see it. But since it was only 10 minutes away I Let the seller know I was still interested. Really clean and fast car. I'll get some pictures up in the near future.
    Its ready to drive to The Vintage. New tires, refurbished Becker Mexico, fresh fluids, valve adjustment, recharged AC, and a nice hiway drive tonight has me feeling pretty good about the 1400 mile round trip to Asheville.
    BTW the rapid flash was due to the wrong size (small) bulbs.
    talk to you soon,
    john
    Dec 2007
    Gilbert, Arizona
    6/83 1984 745i
    Looks very clean. Also interested in the turbo upgrade.
    alpinweiß on anthrazit buffalo 1984 745i, 2014 Fiesta ST, 1984 635csi 1986 635csi 1987 L6 1999 M coupe 2002 M3 1995 325i 1976 200​2, 2001 996 TT 1994 850 T5 wagon 1998 GTi VR6 1983 scirocco
    Dec 2013
    PA
    2000 M5, 2001 330i
    I remember seeing this on ebay. I had told the owner to list it on BaT and he ended up replying and giving me his cell phone number. Not sure how that worked out....
    Glad to see someone here got it. I still have yet to see another 745i on the roads, someone a mile down the road from me has a black US spec 733i or 735i sitting in the driveway, been meaning to hop in my car and knock on the door.
    2000 BMW M5 Evolve Alpha-N Tune, Evolve Carbon Fiber CAI's, UUC Short Throw Shifter, Dinan Front STB, Dinan Rear Sway Bar
    2001 BMW 330i ​Dynavin N7 Pro
    1985 BMW 745i 18" Style 37's, Team745i Chip, Getrag 265/6, Clutchmasters FX-300, UUC Short Throw Shifter, Strut Tower Bar, Bilstein HD's ("Build" Thread")(SOLD)
    1986 BMW 735i Getrag 265/6 Swap, Strut Tower Bar, Bilstein HD's, Euro F/R Conversion, 3.46 L/S Diff (Scrapped)
    2016 Ford Mustang GT Performance Pack Stock
    2004 Mercury Marauder
    Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, 4.10's, Stainless Works LT's, 2.5" Exhaust, Borla Stingers, FX-R projectors, Addco F/R swaybars
    2003 Mercury Marauder JLT CAI, SCT Xcal4, Stainless Works LT's, SW 2.5" Catback
    1996 Ford Bronco
    4" lift, 35" BFG A/T's, MH1 projectors
    Portland, OR
    Updated
    Hi,
    So I’ve had my e23 745i for a year. I’m learning more about “upgrades” by the PO. This is my first turbo.
    It Has an e28 fuel system wiring harness and chipped 059 ECU installed. I don’t know which chip is installed. PO can’t remember. Since it has an e28 fuel system harness does that mean it has e28 injectors? The car is running rough right now. I suspect it’s a fuel issue.
    Any performance chip recommendations?
    This is the wastegate installed. Anybody recocogize the brand. My boost gauge stopped working, could the wastegate be the cause? I’m think about buying the Miller unit for sale on the forum. Is that good upgrade. Garret turbo unit is also installed in the car.
    Also so has a “boost control” gauge. PO said he never adjusted it in all the years he owned the car. I’m afraid to mess with it. Any advise?
    Other than what I’ve mentioned and an adjustable fuel pressure regulator, the engine is completely stock.
    Id like to get it running smoothly.
    Thanks,
    John M
    Mar 2013
    USA
    E21/early e23/e34
    I'd bet that the ECU has been chipped but not understanding at all why it's running on a 059 ECU- I'd pull the ECU and double check that.
    That wastegate looks like a team745i unit or for sure a modified original to allow for more boost. Also looks like your magnetic valve isn't hooked up/missing a vac hose.
    That knob is an internal cabin boost control, allows you to dial in more/less boost from inside the car.
    I'd make sure all vac lines are hooked up correctly including rrfpr before I'd play with that boost control.
    Car looks good, don't remember seeing it before
    Portland, OR
    Quote Originally Posted by kojo96 View Post
    Thanks for the reply. I’m told the 059 ecu was installed to be compatible with the e28 harness.
    I was wondering about that magnetic valve. As the picture shows one of the vac connections on the magnetic valve is capped the other connects to the wastegate. Where should I run a vacuum line from to the capped connection on magnetic valve? Also, should there be an electrical connection to the valve?
    sorry if these are dumb questions, this turbo stuff is new to me.
    I will be checking the lines to the boost gauge soon to make sure they are all intact.
    Oct 2007
    Valley Village, CA
    1985 745i
    Nice looking car!
    The 059 ecu isn’t much better than the factory 745 unit. It’s still on motronic 1.0, which is less than desirable for turbo applications.
    Are you looking to get this running with what it has or improve it?
    First step is to make sure there are zero vac leaks. Is it running the icv from the e28 as well? I imagine so. Take a shot of the engine bay and post it here. I bet you have quite a bit of hodge podge wiring and vac stuff going on.
    When your enemy is making a mistake, do not interrupt him.
    Portland, OR
    Quote Originally Posted by yert315 View Post
    Nice looking car!
    Yes on the e28 ICV. The car ran great on a 1500 mile trip last year. Then it start running bad delivering to much fuel. But it was intermittent. Sometimes it would run fine some times really rough and stall. Also hard to start sometimes acting like it had vapor lock and barely crank. Replaced the FPR but that didn’t help. My mechanic replaced the 059 icu with a used one, swapped in the performance chip from the old one and that seemed to solve the problem. It’s running rough again but not as bad as last time.
    if I’m going to replace the ICU again I would like to upgrade and also replace the injectors.
    any suggestions or direction would be greatly appreciated.
    Here are some pics of the engine bay:
    I have a starte up button wired in th diagnostic port due to a faulty insinuation switch I’ll be replacing soon
    Three added relays. Need to find out what they’re for:
  1. New to me 745i
    By alabbasi in forum 1978 - 1987 (E23)
    Last Post: 09-15-2015, 09:29 PM
  2. New (to me) 745i and a question
    By sully32 in forum 1978 - 1987 (E23)
    Last Post: 07-26-2014, 09:29 AM
  3. 2nd addition to the fleet - New to me 86 325e
    By trendyincdotbiz in forum 1983 - 1991 (E30)
    Last Post: 03-10-2010, 01:22 PM
  4. Replies: 7
    Last Post: 12-26-2002, 05:43 PM
  5. Wozup all New to the boared 745i owner.
    By BiMMer745i in forum 1995 - 2001 (E38)
    Last Post: 04-30-2002, 11:59 PM
