Results 1 to 14 of 14
Thread: M73 Heads Vs M70 Heads
    Christchurch,New Zealand
    93 fjord grey 850csi
    sure i posted this already but i cannot find the thread
    but apart from the obvious roller rockers what is the differences
    like can these heads be modified to flow better than the M70 heads or are they still the limited by the exhaust ports
    Jun 2012
    Uk
    1994 850csi rhd
    Not sure but I looked at the M73 headers and they were more restrictive than the M70
    Jun 2012
    Uk
    1994 850csi rhd
    The manifolds are definitely smaller diameter, I measured them side by side.
    Nov 2013
    Whitney, TX
    97 850CI
    Page 22 of the M73 Engine Training Reference Manual suggests otherwise.
    Desecrator of all things Sacred
    Nov 2013
    Whitney, TX
    97 850CI
    San Jose CA
    1991 850i S70 6 speed
    Merlin840, there is a local E31 owner that has done m73 head swap into a m70 and it is a very fast car. You might touch base him.
    Alex Molavi
    Quote Originally Posted by merlin840 View Post
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by 72tpik5 View Post
    which is exactly why I purchased a set to install on my car. Then once I had the standard ones removed I could see that was definitely not the case.
    https://www.bimmerforums.com/forum/s...-850CSi/page12 see post #300
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by Omega man 1969 View Post
    I would say hands on experience win over the factory publication any day. Thanks for the info.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Why not go all the way and put the M73 engine in the car by slightly modifying it like WOKKE has done many times. You get larger displacement, roller rockers, better oilbar design and much more HP. Added bonus: you can run everything in M70 electronics. There is a great write up here about it if you haven't already read it.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Canada
    750 F01, 850i, LR3 HSE
    The M73 stainless steel manifolds are larger internally, they are "necked down" at the inlet and taper off at the outlet. I have measured these has well, correctly. We had to pull this (M73) motor apart in BMW NA class back in 96' and measure then confirm the differences against the M70.
    Mark.
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Quote Originally Posted by TxGR8White View Post
    I am pulling the trigger on a used m73 engine this week for this very project. I posted on another thread, but didn’t get an answer. Is it possible to use the M73 (from e38) manifolds and stock downpipes from the M73 850 to address the issues with mating up to the rest of my ‘91’s stock 850 exhaust?
    Sent from my iPad using Tapatalk
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by mandd View Post
    Mark.
    Being a 4 stroke a larger internal with smaller inlet will restrict power. Only 2 strokes gain from expansion pipes.
    Canada
    The difference in the inlet outlet ports is not enough to make considerable gains with this motor. The goal with this engine was linear power delivery and driving comfort. Even when fitted with headers the gains are minimal unless you are using larger cams, modified heads etc, even then the gains are small.
    Mark.
    Jun 2012
    Uk
    1994 850csi rhd
    Mark.
    The only way it would make more power compared to the bored out M70 pipe is if the M70 pipe was too big and reduced exhaust velocity. It was too small and the M73 was smaller still... at the inlet, which in turn will cause more back pressure. The only advantage the M73 would have would be in the low to mid range where velocity will be increase and volumetric efficiency increased as a result. At wide open throttle and max power the M73 pipe will be less effective......than a bored out M70 pipe.
    Both heads are restrictive enough as is, they don't need any additional back pressure to make things worse.
  1. 325e head vs 325i head?
    By Jeremy Lucas in forum 1983 - 1991 (E30)
    Last Post: 06-06-2021, 05:17 PM
  2. What's The Diffefence? OBDI Head VS. OBDII Head?
    By 84 332i in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2009, 12:23 AM
  3. What's The Diffefence? OBDI Head VS. OBDII Head?
    By 84 332i in forum 1991 - 1999 (E36)
    Last Post: 12-05-2008, 02:19 PM
  4. 87 head vs 84 head?
    By TomC in forum 1982 - 1988 (E28)
    Last Post: 11-13-2007, 10:43 PM
  5. Cam Rotation - 320i Head vs. 318i Head?
    By DaveITB1 in forum 1975 - 1983 (E21)
    Last Post: 07-14-2006, 08:41 AM
