Results 1 to 24 of 24
Thread: CSi gauge cluster on the cheap...
    Nov 2014
    Milledgeville, GA
    1994 Alpine White 840Ci
    Didn't think that this simple trick would work out as well as it did, but taking a cue from another forum member, I removed the instrument cluster from the vehicle over the weekend and performed the infamous Sharpie trick on the pointers.
    The only advice I would give others is to down two or three beers prior to starting the application to steady the hand while applying the sharpie ink.
    At 59 years old, the hands are not as fluid as they once were.
    Millennials need not apply!
    Pic attached.
    '94 840Ci "Broomhilda"
    Mission Creep |def|: "When repair X ultimately leads to repair Y and Z"
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    I have to agree that looks good. When illuminated, how do the red needles look?
    I haven't driven my car in so long, I don't remember what my cluster looks like without referring to an old photo:
    Nov 2013
    Indianapolis, IN
    97 850CI
    Looks good. One more thing added to the "to do" list.
    Desecrator of all things Sacred
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Red needles look good, but it's still a long way from resembling a CSi cluster.
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
    Orange County, CA
    E31 & E89
    Quote Originally Posted by kiwiCSi View Post
    I was biting my tongue...
    What he made was the "Japan Individual 840Ci" cluster.
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Except for the speedo scale....
    Current:
    Previous:
    1987 E28 M5 Delphin
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Please don't do "sharpie" trick...
    Get E36 M3 needles and with a little modifications they will look stock on ours E31.
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Make Bimmerforums Great Again
    What "thumbs up" really means
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Or... go full bore and install the actual CSi gauges.
    Bert
    91 850i-A
    72 3.5 CSi (L-jet, Getrag 265 5 speed)
    88 ///M6
    The back to back to back "BIG COUPE" triplets
    Las Vegas, NV
    1994 850CSi, 2007 M5
    Only 26,500km on the clock! Can't believe you have been behind the wheel long enough to notice the needles!
    1994 850CSi, 2007 M5, 1990 VW Westy Syncro
    Nov 2013
    Indianapolis, IN
    97 850CI
    Since I already have a red Sharpie, I am going to use it. Quick and cost effective. And the money I saved from not buying a CSI cluster will be reallocated to buy something else I don't need for Eva.
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Quote Originally Posted by Major Cheese View Post
    ......yeah, that picture was taken the day I first bought the car, back in 2013....and yes, the odometer reading certainly draws attention away from the subject of the needles!
    However I'm pleased to report that it's done a few more kms since then - 31,500 now.
    Back on topic, the Sharpie method appears to do the trick, but I also like the idea of swapping out the needles rather than painting them - a good option if you're going to all the trouble of getting access to them.
    And while you're in there, if your speedo is an imperial instrument, why not de-clutter the dial face by blacking out that annoying km/h scale?
    Current:
    Previous:
    1987 E28 M5 Delphin
    Regina SK. Canada
    1991 850i / 6
    Blanz, did you remove the needles from their axels or did you paint them while still attached? Once you pry off the needles it is a simple matter to lift off the gauge faces and replace them with custom made ones. Way cheaper than buying a CSi cluster. I used hobby shop paint to do mine.
    Nov 2014
    Milledgeville, GA
    Quote Originally Posted by garylafortuna View Post
    I removed each individual gauge from the backside and then applied a single pass of the sharpie. I say single pass because you do not want to deposit too much ink that would impede the translucency of the needle. Ask me how I know.
    A single pass of the sharpie gives a good contrast of color while still illuminating at night when the lights are on.
    Kailua-Kona, Hawai'i
    840ci
    Can you describe the "little modifications"?
    Quote Originally Posted by dancerst View Post
    Jul 2015
    What difference does the E36 M3 needle have vs the E31 needle?
    Sent from my SM-G930F using Tapatalk
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Now he can try this:
    Nov 2013
    Indianapolis, IN
    97 850CI
    Which also looks good. Do they illuminate as needed?
    dancerst's Avatar
    Virginia Beach, VA
    Quote Originally Posted by tangcla View Post
    What difference does the E36 M3 needle have vs the E31 needle? Sent from my SM-G930F using Tapatalk
    The difference is in the hole diameter.
    E31 needle pins are thinner.
    You have to take E36 needle, heat up the hole end with a lighter or torch and press it agains something flat, it will expend melted plastic slightly, just enough to sit firm on E31 pin.
    E36 stock needle
    Modified:
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Quote Originally Posted by 72tpik5 View Post
    No, just light as usual. However, I did put in LEDs, so they are brighter.
    Nov 2013
    Indianapolis, IN
    97 850CI
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Would look so much cleaner without the km/h scale...is that a legal requirement in the US?
    Current:
    Previous:
    1987 E28 M5 Delphin
    Nov 2013
    Indianapolis, IN
    97 850CI
    Not to the best of my knowledge.
    Nov 2013
    Indianapolis, IN
    97 850CI
  1. How to remove the gauge cluster on an e36
    By hamlet in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-17-2010, 02:35 PM
  2. Thinking of doing a A-pillar Gauge pod on the 318ti.
    By Panzer_M in forum 1991 - 1999 (E36)
    Last Post: 06-18-2004, 01:56 AM
  3. new muffler on the cheap?
    By miatawnt2b in forum 1991 - 1999 (E36)
    Last Post: 05-07-2004, 03:05 AM
  4. Help with gauge cluster on 89 325i
    By jonmacs22 in forum 1983 - 1991 (E30)
    Last Post: 02-16-2004, 01:33 PM
  5. Following up on the cheap system thread
    By Texas M3/4 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-30-2004, 04:51 PM
