When i put the car on the computer at autozone. It gave me misfire codes. So they suggested fuel pump change. It did not work. Most of the time when i press the gas before it revs it almost stalls. During winter i had to keep it alive by constantly pressing the gas until a little warm. Usually when warm it does not happen as often. Can anyone suggest something as i do not have money to try each code issue. It had 139000miles. Thanks
Please post the ACTUAL codes for a correct diagnosis.
My bet is a vacuum leak. I know that sounds like a broken record and we've all heard/read it too many times, but IMNSHO it is the single most common problem with any fuel injected engine. Every EFI engine has to have correct info sent to the ECU so that the correct amount of fuel is provided. Garbage in, garbage out, right?
So tell us all how you've been convinced that this is not a vacuum leak problem, it sure sounds like it to me...
Charlie
Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
I agree with Honolulu. It is most likely a vacuum leak or also check if it's due to a weak ignition coil.
Thanks guys for a fast respond i took the car again for code checking and there is the following:
0313
300
1349
1351
1343
0171
1345
1347
0174
Please tell me what you guys think i need, remember i already change the fuel pump, thanks
It sounds to me like a vacuum leak as well. Quit taking your car to autozone. All it's gotten you is us less money in your pocket and a questionable fuel pump.
P codes can be very misleading. If you need a scan, get it done by someone with a BMW scanner or buy a scan tool.
