Results 1 to 11 of 11
Thread: Whistling nosie from the intake?
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Hey guys,
    I have a new noise coming, I believe, from the intake under the cover cap. I have attached two videos. I did not have this noise before and Its only I picked the car up from a shop (where they were checking emmissions) that I noticed this sound. Vauum distribution lines are new and Ive made sure they are tight. Any leads? Can this be a loose spark plug? Ive heard on other threads that it makes a whistling sound.
    thanks for any insights shared.
    https://youtu.be/IM9Wc3_bWvE
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    I can't tell a thing from these videos. Is your idle speed normal? The gasket at the IAC has been known to fail.
    /.randy
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Randy, I'll describe the sound. It is like a tiny dental drill playing a single note on a flute and made my stomach churn. It's really high.
    I looked for my vacuum leak by putting a pry bar on the gas pedal, putting a cylindrical object in the filter end of the intake, tightening the intake clamp, and putting about 3-4 psi regulated compressed air into the intake system. Then I listened for the whistle and sprayed the intake with soapy water. I also opened and closed the oil fill cap let off pressure.
    All this because I can't run the smoke machine part.
    It does sound like a loose spark plug to me...
    PRICE CUT on ALL FABRICS
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Update: i dont think its a spark plug since that is more of a "knock" sound as opposed to a whistle, but Ill check them anyways since it doesn't hurt. I think that the recently installed ccv is bad. It is a valeo from ecs....Once I lift the dipstick, the whistle goes away.
    here is another video that hopefully sheds more light
    https://youtu.be/QHnlg2xlMS8
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Quote Originally Posted by LannVouivre View Post
    Couldnt have said it any better. Maybe an orchestra of people scratching chalk boards with their nails?
    It sounds to me like a bunch of tone deaf grasshoppers were instructed on how to play the banjo duel from the deliverence by someone who had never actually seen that scene in the movie.
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    I like where this is headed!
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by RedZeddy View Post
    Is that what the guy in the video is doing to turn off the sound -- lifting the dipstick to unseal the crankcase? Worth trying another CCV.
    I had mine replaced with the cooling system. I let the shop provide it so don't know what brand they used.
    Is this "Genuine BMW" from ECS the Valeo CCV (PCV) that you got?
    https://www.ecstuning.com/b-genuine-bmw-parts/crankcase-vent-valve/11157501567/
    BMW MOA 696, BMW CCA 1405
    Jul 2015
    Washington DC
    1997 BMW Z3 1.9L
    Yes, that is what I was doing in the video. The ccv I installed was also after a full coolant system refresh. I made the mistake of saying it was a valeo ccv, it is in fact a Vaico
    https://www.ecstuning.com/b-vaico-pa...157501567~vai/
    i have ordered a pricier one from FCP to see if that does the trick...
    Jun 2016
    Odessa, TX
    The Import Direct line from O'Reilly Auto was literally a BMW part in a BMW bag shoved in a DI box for $68 ($80ish from most everyone else). You can try and see if you get the same results. My local shop even had one in stock.
  1. Replies: 2
    Last Post: 08-30-2013, 02:45 PM
  2. Whistling noise from the engine
    By InCahoots in forum 1999 - 2006 (E46)
    Last Post: 09-27-2012, 10:14 AM
  3. Whistle noise from the center air vent
    By dgcccom in forum 1999 - 2006 (E46)
    Last Post: 05-03-2010, 01:30 PM
  4. Hissing sound from the intake M62
    By SpeedsterBek in forum 1996 - 2003 (E39)
    Last Post: 09-18-2009, 05:09 PM
  5. Strange Whistle Coming From the Car....
    By simpsoap in forum 1996 - 2003 (E39)
    Last Post: 07-04-2007, 10:04 PM
