Tons of refreshed e36 parts
I just sold my e36 and bought an e46 ZHP so I need to sell off a ton of extra parts. I prepped all these parts and planned to install everything when I boosted my e36. Now I want to get this stuff out of my garage and I?m willing to sell everything as a package. Most of the parts were either sandblasted and painted black (steel parts) or bead blasted and cleared with a high temp satin clear (aluminum parts). I?m sure I?ve got other parts besides these too, this is just what I had lists for. I don?t have the transmission, driveshaft, hubs or front control arms. I'd rather not ship but will you if you pay. If there in't a price listed just make an offer.
M52 engine with LMۈ][[H\Y[\\[XY[\Y܈XX[[ˈ\\HY[Y[[YY[\\HX[YYY[X[YH
L[Y\XYܘ[[\]BMLTXYYH MLBMLБ\[\\Y[Z[[XܜQHH BБ[ZHX[YBX\X[YH]Z[ܘY^H\[[
[YYZ[Y
HH MLBX[YH]Z[ܘY[܈[[]\
Z[YXHH LB[܈[[
X\]Y
CBY\[X
YYHXZ[
CB[[\\[
X\]Y
HH
CB[Z\[ۈܛY[X\
X\]Y
CBY\[Y
X\]Y
CB\[]\[
X\]Y
CBZHX\\[[\
X\]Y
CBY\[[ۙ\B\Y\[[\
X\]Y
CBPX]
X\]Y
CBY[[\ݙ\
Z[YXCB\XXH
Z[YXCBX\\\\\
Z[YXHH
LBYX][ۈ[\[\
Z[YXCBܘ[[^H
Z[YXCB\Y\[[^H
Z[YXCB]\[\[^H
Z[YXCBY[[\[]BP[\
Z[YX[X\]Y
CB[܈[[X]Y[B\H\
X\]Y
CBX\\H[[
Z[YXCB[\H
Z[YXCBZH\
Z[YXB\HX\YH\H
XXBBB\]N
KMǨMBB܈[ܙH[X\HY]HܚY[[\[ΈVOMVTZ˜[˘K؝^Kۜ[ً\Y\YYL͋\\L
]W\OT[ɝ]WYY][OXI]W[\ZYۏT\V[\\[UۜوY\YL͈\TVVWCBKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKCBVOMWU\][H\ۙ\]Z[XKVWCBBTZ˜[˘Kؚ[[Y\ܝ[\VSQZ]X[XY\˜[˘KYܛ[ܙKSQVTCBKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKCB
Panjo sucks. Here's what I've got for sale
M52 engine with ~160k on it. Engine has been disassembled and prepped for machining. Block was wire wheeled and primed. All parts are cleaned, bagged and labeled. - $500 Includes head, crank, cams, etc
M52 ARP head studs - $150
M52 OBD2 wiring harness, fuel rail, injectors, DME - $200
OBD2 intake manifold
Rear subframe with reinforced sway bar mounts (primed not painted) - $150
Front subframe with reinforced motor mount plates (painted black) - $100
Motor mounts (clearcoated)
Steering rack (needs to be rebuilt)
Oil filter housing (clearcoated) - $75
Transmission crossmember (clearcoated)
Steering shaft (clearcoated)
Thermostat housing (clearcoated)
Brake master cylinder (clearocoated)
Idler tensioner
Power steering pump (clearcoated)
AC bracket (clearcoated)
Fuel filter cover (painted black)
Dip stick tube (painted black)
Rear upper control arms (painted black) - $50
Diff vibration dampener (painted black)
Crank pulley (painted black)
Power steering pulley (painted black)
Water pump pulley (painted black)
Fuel pump and floats
ABS pump (painted black and clearcoated)
Motor mount heat shield
Control arm lollipops (clearcoated)
Rear control arm mount (painted black)
Coolant pipe (painted black)
Brake booster (painted black
Coupe rear side glass - $40 each
Check out my current build pics here
Bump
I can't get th3e pics to upload so if you're interested in anything pm me and I'll send them.
