I want to do a manual swap from my 323i to 330ci. I want to know what parts are interchangeable between the 2 other than drive shaft. And will the flywheel clutch and pressure plate fit on a m45
M54*
You'll need your computer flashed or h
Get one with it that is already programmed for a manual. They should swap since they are the same blocks, just different stroke?
Sent from my SM-G930V using Tapatalk
other than the computer flashed, i want to see what i will be able to transfer from my 323i to my 330ci (mechanically). already have that part sorted out
Mechanically, I'm not sure. Driveshaft will be different. And not sure on the rear subframe. I'm taking my whole motor and driveline out of my 330i and putting it in a 325i currently. I have yet to see a coupe, and really tear into it.
Progress on this??
transmission and driveshaft will bolt up fine. Computer just needs adaptions cleared once the transmission computer is removed.
As mentioned the diff ratio is different, and i believe the 323 had a smaller diff and rear axles in it.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
Wow, forgot to update this thread, i did everything and it has gone smoothly, gave the car to my brother and he is enjoying it
The 330i diff with manual trans is 2.93 fyi
Good! I have a m54 swap in my 325i. Everything bolts right up. Easy swap for sure
Is the new tranny a 5-speed or a 6-speed? The 6-speed tranny is longer. Also, BMW changed the number of splines on the the tranny’s input shaft somewhere during the production of the E46.
