Results 1 to 10 of 10
Thread: E36 cut springs? Lol
    May 2017
    Missouri, United states
    1992 bmw 325is
    I was asking a guy at my local "bmw" shop about budget suspension. He said h&r is pretty good but if im on a tight budget i could cut down the spring a little to lower it. Would that work decent if i buy some aftermarket/better shocks to go with it?
    Oct 2003
    Seattle
    99 M3
    It would be possible to cut the front springs as they are a constant winding (initially) for a coil or two. The rate of the spring will increase with fewer coils. Typically, lowering springs can be slightly softer as they lower the row center of the vehicle. Additionally, some tend to be more linear and less progressive in rate.
    The rears are different, a beehive shape. No way to cut these.
    You are going to be better purchasing a matched set of aftermarket springs, you might save some money buying a good set of used.
    Both Koni and Bilstein produce quality products, shock and spring kits are available.
    Sachs and Boge produce stock factory (non lowering) replacement shocks/struts, if budget is a concern.
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    I have bilstein stuff that will for your car. PM me if interested.
    Dec 2013
    Chicagoland area
    EXOTICS
    Oct 2003
    Seattle
    99 M3
    Look at shock/spring combos from Bilstein, Koni, and H&R. Shy away from constant diameter (2.25 or 60mm) spring set coil-overs as they will most likely require spacers on front hubs for wheel/tire clearance- https://www.tirerack.com/suspension/...s&autoModClar=
    Look to ECSTuning (and others) for price comparisons. Consider shipping costs.
    Aug 2013
    1999 BMW M3 Coupe
    Don't cut your springs. Get a quality suspension kit. End of thread.
    Dec 2013
    Chicagoland area
    EXOTICS
    Exactly, stay away from that BMW shop, or at the very least, that mechanic who foolishly suggested cutting the springs.
    My previous post containing the link to tirerack, has some good options for you.
    Jan 2017
    Rome, Ny
    M3
    I used cut springs on a convertible upfront and coupe rear springs for a year. No issues. Worked very well for a 1" drop. Cost me $20 and a cutting disc.
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by M3blitkrieg View Post
    NOT recommended.
    Aug 2013
    1999 BMW M3 Coupe
    It's sort of like saying "I drove around for a year with no seatbelt and had no issues."
    Just because you can doesn't mean you should. In the case of springs, depending on the type, cutting them can change their stiffness and properties. Also, unless you hand taper the cut end it won't sit right on either the spring perch or hat. It's important that both ends of the spring sit flat.
  1. Cutting springs on e39 lol
    By MoeBuilt in forum 1996 - 2003 (E39)
    Last Post: 03-27-2015, 03:54 PM
  2. outcome of Front cut springs on e36
    By Mr318i in forum 1991 - 1999 (E36)
    Last Post: 04-29-2013, 09:30 PM
  3. E36 Looking for e36 rear spring height adjuster
    By gardar in forum BMW Parts Wanted
    Last Post: 07-01-2010, 05:42 PM
  4. E36 E36 Vorshlag Springs/Bilstein Sport Shocks/
    By hotboxE36 in forum Suspensions, Springs & Shocks
    Last Post: 02-15-2010, 07:22 PM
  5. Pic Request: E36 with cut springs
    By Matteu in forum BMW Rides & Events
    Last Post: 11-18-2009, 08:48 AM
