Results 1 to 16 of 16
Thread: Adjustable sway bar end links for rear, aftermarket bar.
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    I was in need of end links and did not want to drop $100+.
    I ended up making my own and did a few extra sets. I used my set, sold one and have another set left over!
    $75 shipped + PP or friend and fam
    If they sell and more are wanted, shoot me a PM!
    The top bolts are slightly larger and stronger than factory so the holes on the stock bracket need drilled to 3/8". Takes about 5 minute while changing them.
    Okay the order is in. Heres some details for you guys if interested.
    Details -
    The bracket bolts are grade 5 zinc plated with a 60,000lb shear strength.
    The nuts for the bolts are grade 8 zinc plated 1/4 inch
    The top swivel end is Zinc plated rated at 3,950lbs radial max at 12 degrees - carbon fiber, self lubricating lining on the joint
    The threaded rod is 18-8 stainless steel
    The securing nuts are thin grade 8 zinc plated
    The lower shank end is zinc plated rated at 3,950lbs with a 50 degree swivel (states will need lubricated occasionally for best life) I use marine grease and have not had to reapply.
    The washers are grade 8 zinc plated steel
    The lock washers are grade 8 zinc plated steel
    I could have used cheaper materials and cut the cost way down, or used the premium SS stuff and charge what most shops do for mild steel, but this is a good compromise. They will def withstand corrosion, function well and wont break the bank. This info was added to the original post.
    Sep 2010
    Pittsburgh
    99' 328is
    Bump for a solid part from a good dude - these do just as well as the adjustable ones on the market, for a much better price.
    May 2009
    Pittsburgh, PA
    Bump it, thanks!
    Quote Originally Posted by gpricco View Post
    Mar 2013
    Texas
    98' Hellrot M3
    PITT M3 RR - Im interested Pm'd you sir
    May 2009
    Pittsburgh, PA
    Replied!
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    What's the range of adjustability on these? Like on the shortest setting from hole to hole and the longest setting from hole to hole?
    Also, can these be used with OEM swaybars? A lot of the endlinks out there are for aftermarket sway bars only.
    May 2009
    Pittsburgh, PA
    Quote Originally Posted by golgo13 View Post
    Hi, Ill grab some measurements for you ASAP. At the moment its for after market sway bars only as they have a hole vs the rod. Only think I can think to do is find a unit that has a hole with a similar diameter to the stock sway bar end...then have it slip fit with some sort of way to secure it.
    Feb 2016
    Rogers AR
    1995 BMW M3
    do you still have some?
    Sent from my 831C using Tapatalk
    May 2009
    Pittsburgh, PA
    Yes guys, I can have a few sets ready to go this week. When I hit the garage tonight I will et those measurements for you too. Just set an alarm.
    May 2009
    Pittsburgh, PA
    Just to let you guys know, I went to the garage and realized I sold all the sets I had. I am getting the supply for three more and will have it this week. Sorry about that! I though I had one set, but sold it locally awhile ago.
    May 2009
    Pittsburgh, PA
    Lets go with $75 Shipped for the good of the community!
    Feb 2016
    Rogers AR
    1995 BMW M3
    sweet! I defiantly need a pair! don't want to go and pay ground control for some lol
    I'm in no rush by the way, for the project
    May 2009
    Pittsburgh, PA
    Ready to go 3 sets.
    they can get down to 3.5 inches with a single nut.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by PITT M3 RR View Post
    Ready to go 3 sets.
    Thanks dude, appreciate it
    May 2009
    Pittsburgh, PA
    No prob!
    May 2009
    Pittsburgh, PA
    Have some more - been running them with out complaints
  1. Mason Adjustable Sway Bar End Links for the E39 - Review & DIY
    By Graham E39 528i in forum 1996 - 2003 (E39)
    Last Post: 12-07-2018, 02:29 AM
  2. WTT: '97 M3 Sway bar + end links for you Non-M Sway bar + end links
    By stancyeze in forum Suspensions, Springs & Shocks
    Last Post: 07-28-2014, 10:01 AM
  3. E36 WTT: '97 M3 Sway bar + end links for your Non-M sway bar + end links
    By stancyeze in forum 3 series & Z Series
    Last Post: 07-21-2014, 08:52 AM
  4. Replies: 8
    Last Post: 11-02-2013, 11:34 PM
  5. WTB - front sway bar end links for e36 328
    By CdnR328i in forum BMW Parts Wanted
    Last Post: 04-03-2006, 12:03 PM
