Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Latest in Radiators?
  1. #26
    Jun 2014
    Santa Clara, CA
    F30 '14 328i Msport
    Great write up.
    Quote Originally Posted by CMG View Post
    I ended up doing full coolant system refresh with belts and pulleys. I used the Stewart pump and a CSF radiator and everything else was oem. The only other non oem part I used was a water pump pulley. Apparently Uro is the only company that sells metal water pump replacement pulleys rather than composite, so although Uro is usually trash this might be one item of theirs that is ok.
    I guess I've been into these cars long enough to have gone through multiple maintenance periods so guess I'll share my experience regarding long term coolant system maintenance. The miles I drive per year are below average, but it is in a hotter climate, and I definitely drive the cars hard. I think that while my maintenance interval is around every ten years, for many people it may be closer to every 7 or 8 years.
    -Other than a coolant hose or heater core popping a leak somewhere, there are 3 common coolant system big fails IMO:
    -1 is the water pump. Always use metal impellers not composite. Even the OEM composite water pumps WILL fail and fall apart given enough time. Metal water pumps can also fail at the bearing and get loose, allowing water to leak out. If you wanna do it cheap you can use Hepu, and if you want to do it right get the Stewart.
    -2 is of course the radiator neck. There are lots of cheap options like Hella, Behr, E46, etc. but as before any composite end tanks run the risk of falling apart over time. You can get a Behr Hella service radiator for under $150, and replace it every 5 years or so, or for maybe twice that much you can get a direct fit aluminum one that can possibly last the lifetime of the car.
    -3 is what I call the triple nipple. It is a little plastic fitting connecting the 3 engine hoses into the one heater core intake in the firewall on the driver side. In the same way that the radiator neck can break this can break leading to massive coolant loss. At this point in our cars age I would say that it's a consideration to possibly do on any car.
    -The best way to prevent a failure is preventative maintenance, and to do the whole complete system at least every 10 years (some stuff can be re-used, depends on owner discretion). If you don't know when your car last had it done you can look for dates on the radiator or hoses to see how old they are.
    -The bare minimum way is to ensure your water pump has a metal impeller, and to make sure radiator is new or aluminum.
    -Some aftermarket brands are same as OEM (depends on particular item): Behr, Rein, Meyle, Lemforder. Only OEM coolant reservoir should be used.
    -Ensure all parts are mounted properly and secured. In some cases there is less than 1cm clearance between fan and shroud and hoses. Loose attachments and mounts can cause it to catch and grenade. Bad motor mounts or water pump bearing can cause enough shift to do this. The stock top radiator latch mounts kind of suck but they are the only easy option.
    -A well maintained and fully functional coolant system should not have any issues whether it's bumper to bumper traffic or on a racetrack (I also went a couple years without a clutch fan and no issues). It's a real finicky coolant system and I believe I have had to take care of every possibly coolant related failure I could think of. Even though it sucked having to deal with it in a way I was really lucky. For example years ago I had just pulled off the freeway and was sitting at a light and I saw some steam coming up, then as I started to pull over and park the gauge started to move up. When I had the triple nipple bust on me it was like a human getting a bust aorta, straight instant coolant dump, but luckily I was only a short distance from the house and was able to turn it off and coast. Bottom line is if you see or smell coolant, or temp gauge starts to move at all, pull over and park ASAP and check it out. It will go from middle to red in less than a minute, and red can quickly lead to engine issues.
  2. #27
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    I personally recommend metal impellers because it eliminates any chance of any plastic/composite impeller falling apart and getting pieces in the coolant system. I have used both new and old style oem, and have had both fall apart over time. I found one during normal preventative maintenance where the coolant system was working fine, but pieces of the impeller were gone. This one I just did I had used the new version OEM composite and it failed at the bearing, so it could go either way. I would just prefer to avoid any easy fails if possible.
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
  3. #28
    Jan 2015
    Orange County, California
    E36 M3, E90 328i M-Sport
    FYI - I run a stock water pump and Z3 Radiator (Larger and one more pass) on my E36 M3 race car.
    Never had any issues with temp and actually outperform my friends car with CSF all Alloy rad on track. I never see over 190F on my temp gauge, even when it was 106F Ambient at Autoclub Speedway.
    Just replace both every 12-18 months and you should be fine.
  4. #29
    Oct 2003
    Seattle
    99 M3
    Bluptgm3 is correct that the main difference for the Stewart is a support shroud around the impeller to give the impeller support so the bearing doesn't carry as much load.
    It is not so much an impeller support as it a channel to direct water inflow.
  5. #30
    SD, Cali, USA
    I ended up having Oceanside Motorsports replace the complete coolant and pulley/belt system. The CSF and Stewart were used mainly for warranty purposes. Now on to other things....
    95 BMW M3 Alpine-
  6. #31
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by jjwilson89 View Post
    FYI - I run a stock water pump and Z3 Radiator (Larger and one more pass).
    Never had any issues with temp and actually outperform my friends car with CSF all Alloy rad on track. I never see over 190F on my temp gauge.
    What temperature thermostat are you running? Still have belt driven fan?
  1. ** Fan blades break off in radiator **
    By Farmer in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2013, 09:24 PM
  2. Latest in my hesitation/stumbling problem
    By Modena NYC in forum 1992 - 1999 M3 (E36)
    Last Post: 01-12-2004, 08:34 PM
  3. Brown Fluid in radiator and on dipstick & rough idle
    By '95 325is TX in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-07-2003, 10:19 PM
  4. Latest in the M3 engine failure saga
    By dysphunxion in forum 2001 - 2006 M3 (E46)
    Last Post: 08-01-2002, 11:44 PM
